PLEASE HELP!!! What clutch will work in my JDM b16a SiRII motor???
i have a 97 ex civic with a b16a SiRII motor. It has the lsd tranny, i was just wondering if a clutch that will fit a 99-00 SI will work on my car as well. if not what should i look for?
as of now i have exhaust and intake and plan on doin a header and maybe a cpl more light mods. should a stage one be sufficient? i was gonna do the exedy stage one clutch with fidanza 7.5 pound flywheel...
well i bought this kit: http://cgi.ebay.com/ebaymotors...ZWDVW
which is a 99-00 civic SI kit. i was told by gripforce it will fit my SIRII motor but im not sure i believe them so if someone can get back to me on that for some reassurance that would be awesome!
From: IN YOUR BASEMENT, ON YOUR COMPUTER, minesota, united states
tell you right now from experience, your going to have alot of problems shifting with that light of fly wheel but when you get use to it. alot of fun.
I put down almost 300 hp on the street with a stock clutch on a B16 tranny before it started to slip. Of course, when I acually got traction with some slicks, that clutch was done for...
I was still REALLY surprised at how much abuse a stock unit can handle on a b series...
You should be just fine with the stock one...if you REALLY have to put something stiffer in it. Get the exedy stage one. It uses a stock disc, with about a 26% (if I remeber correctly) boost in clamp load over the stock pressure plate. I have this in my 12 sec. daily driver. It's VERY driver friendly. Almost just like stock, only a little stiffer pedal...
http://www.exedyusa.com/race/08800B
I was still REALLY surprised at how much abuse a stock unit can handle on a b series...You should be just fine with the stock one...if you REALLY have to put something stiffer in it. Get the exedy stage one. It uses a stock disc, with about a 26% (if I remeber correctly) boost in clamp load over the stock pressure plate. I have this in my 12 sec. daily driver. It's VERY driver friendly. Almost just like stock, only a little stiffer pedal...
