Popping sound when turning/going over large bumps
Old Mar 25, 2007 | 10:48 AM
rocket30004's Avatar
Default Popping sound when turning/going over large bumps
So here in MI the roads are pathetically bad. Went over a fairly large pothole at speed the other day. Since then when I turn (left only) I hear a popping sound on ocassion NOT all the time, and a similar sound when going over bumps.
Normally ppopping while turning = bad CV joint, but it's more of a pop than a click sound, and is sporadic not constant (just one pop overy once in a while, not a constant click-click-click-click every time I turn --- which is what I experienced when I had a bad CV joint in my old civic).
Could it be a ball joint or something? How do I diagnose it as a bad CV vs. something else?
Thanks
Old Mar 25, 2007 | 10:55 AM
GraphiteMW's Avatar
Default Re: Popping sound when turning/going over large bumps (rocket30004)
It can be the CV axle, the first few months of my CV axle going bad it would only make noise if I get on a dirt road or go over speed bumps then it worsen to having the knocking/clicking sound while I accelerate and take turns. So replace to the CV axle to be safe.
Check your CV boot for rips or lots of grease, that means its going bad.
Old Mar 25, 2007 | 11:20 AM
Aahj's Avatar
Try checking your balljoints and sway bar endlinks.
AJ
Old Mar 25, 2007 | 12:06 PM
britishdude's Avatar
Default Re: Popping sound when turning/going over large bumps (Aahj)
My swaybar endlinks caused exact similar noise, found wear and replaced all okay now.
Old Mar 25, 2007 | 12:43 PM
andre809_lude's Avatar
Default Re: Popping sound when turning/going over large bumps (britishdude)
upper ball joints!!! i had the same..
Old Mar 25, 2007 | 04:44 PM
Default Re: Popping sound when turning/going over large bumps (andre809_lude)
Thanks for the responses
I hope it's not a CV slowly going bad...
But, if it is a swaybar endlink and/or ball joint, what am I looking for to see if it is "bad". Does the swaybar link have a boot and joint like a ball-joint? Should I just look to see if it is ripped/torn/etc. or is there another/better way to diagnose?
Old Mar 25, 2007 | 05:30 PM
GraphiteMW's Avatar
It has rubber mounts on them, check for deteriation/cracking
Old Mar 26, 2007 | 10:18 AM
Default Re: Popping sound when turning/going over large bumps (GraphiteMW)
I didn't get a chance to inspect anything yet, but I did notice that it does the sound when it is neutral and in gear... not sure if that helps w/ diagnosis, but I clearly remember that on my civic, it made the clicking sound from the CV joints only when in gear.
I'll check try and get under there today/tomorrow and see whats up... thanks again guys!
Old Mar 26, 2007 | 02:56 PM
MooJenLude's Avatar
Check all the boots you can possibly see. Jack the car up and take off the wheel inspect closely because even a small tear can be a bad one. If any of the linkage/joints has/have a grease fitting you might want to grease it.
Old Mar 31, 2007 | 09:51 PM
Default Re: (BurberryLude)
Well, got a chance to poke around today
On the pass. side, the end-link was broken/disconnected, so it needs to be replaced.
Haven't found a write-up (or even where it is in the FSM) but looks like it should be easy.
Anyone have a link to a write-up or page # in FSM?
PatrickGSR94
Suspension & Brakes
19
Nov 29, 2008 06:09 AM
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
B00ST2nR
Aug 6, 2006 06:32 AM
pho iz good
Mar 18, 2005 04:48 AM
amolm
20
Jan 4, 2005 08:22 AM
