Need help H22 eg
Old Mar 25, 2007 | 09:30 AM
1greatEG's Avatar
Default help H22 eg H22 guys chime in
i am planning on buying a h22 eg. I would like to know a few things. I have been out of the import seen since 98 i had a kid. I have read juss about all the info on this site about H22 swap. I would like to know some of the the guys that have suspension setup. I also plan on getting the head built asap for winter turbo build. What kind of valve train would u guys recommend. I juss been gone for awhile and need some help I will have more questions.
Old Mar 25, 2007 | 06:24 PM
1greatEG's Avatar
Default Re: help H22 eg H22 guys chime in (1greatEG)
nobody with an h22 to help a brotha out.
Old Mar 25, 2007 | 06:28 PM
blacktsi's Avatar
my suspension i had on mine was a kyb agx 4adj/progress h springs did good not to bad on the axles drove great. hope that helps a bit. Also i had rocketmotorsports valvetrain pretty good
Old Mar 25, 2007 | 06:29 PM
ke98248's Avatar
Recommended suspension set-up:
Megan Racing:
Front & Rear Upper strut bars
Front and Rear lower strut/tie bars
H-Brace
LCA's (if you wanna spend da $$ for the looks)
Short Shifter (it's nice, not part of suspension, but oh well)
Adjustable coilovers
Shocks
Camber Kit
C-pillar bar (not on coupe, won't help u at all)
Old Mar 25, 2007 | 07:50 PM
MR.johnson's Avatar
Default Re: help H22 eg H22 guys chime in (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Recommended suspension set-up:
Megan Racing:
H-Brace
Shocks
Camber Kit
what? most the stuff you listed is junk.
Old Mar 26, 2007 | 01:24 PM
1greatEG's Avatar
Default Re: help H22 eg H22 guys chime in (man with one cam)
thanks for the help man i appreciate it. checking into it right now.
Old Mar 26, 2007 | 03:29 PM
wrx'n you's Avatar
here as the specs on my h22 ek.
tokico 5 way adjustables
ground control coilovers
Place Racing axles
Password JDM 3 point front strut bar
Password JDM 4 point rear strut tower bar
some POS rear B pillar bar
Omni power LCAs
CTR rear sway bar
Place racing mounts - which were horrible. wayyy too much vibration
and as for brakes, i just had GSR front and rear disc brakes.
Old Apr 16, 2007 | 05:37 AM
h duce coupe's Avatar
Default Re: help H22 eg H22 guys chime in (projEKt B)
i got the omni powers 12k front 10k rear.. work great!
Old Apr 16, 2007 | 05:55 AM
instrument's Avatar
have you checked the hybrid forum, there are huge posts there about h22 swaps..
EGh22please
Dec 28, 2004 09:18 PM
Insperation
Aug 25, 2004 12:25 PM
2Point2EH2
11
Nov 27, 2003 06:16 PM
