MY CIVIC EG HORN DOESNT WORK HELP..!!!!!!!!!!!!!
for some reason my horn doesnt work out of no where ....how to fix this problem??
when i press horn i hear a clicking sound but it doesnt horn please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 »</TD></TR><TR><TD CLASS="quote">I had the same problem. Replace your horn its BLOWN/GONE. Replace and beep away.</TD></TR></TABLE>
x2
What you hear is the horn relay. I replaced mine with an aftermarket horn.
x2
ok mine stopped working about 2 weeks ago along with the cruise control and windshield wipers... not sure wtf happened but i got the wipers back by messing with the harness that goes to the fuse box... really weird though it happened all at one time. All fuses are fine, any ideas anybody?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 »</TD></TR><TR><TD CLASS="quote">I think your fuse is not blown, coz reply click = have power
the relay click doesnt mean it got power to the horn. if you understand how relay work, it can still blow a fuse(meaning the fused power to 30 side of the relay is blown, hence no power to the horn) while the relay is energized(mean 86 and 85 side got power and ground).
</TD></TR></TABLE>the relay click doesnt mean it got power to the horn. if you understand how relay work, it can still blow a fuse(meaning the fused power to 30 side of the relay is blown, hence no power to the horn) while the relay is energized(mean 86 and 85 side got power and ground).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatchance187 »</TD></TR><TR><TD CLASS="quote">ok mine stopped working about 2 weeks ago along with the cruise control and windshield wipers... not sure wtf happened but i got the wipers back by messing with the harness that goes to the fuse box... really weird though it happened all at one time. All fuses are fine, any ideas anybody?</TD></TR></TABLE>
Check grounds and relays
mine worked today..after i check everything out...
1) i checked to see my work is good or not...
2) check the wire's...make sure is good to go
those are the two step's i done and
i found out is the wire.problem..replace a new wire
my horn is BEEP BEEP TO GO
hope this help's
hope this help's
