head gasket replacement
my car is smoking white & oil coming out of the exhaust. what all do i need to replace my head gasket? what else do i need to replace? is there any special brand i should be using.
this engine is bone stock and always will be
and i can't find any head bolts around here...
Two things to remember when changing your headgasket...
1) D16Y8 OEM Headgasket is around 27$ from the dealer, and it is MLS so you'll never have to scrape that stupid paper goo off again.
2) ARP Head studs come out to be about 30% more than new OEM head bolts (P/N 90005-PM3-003), but that's close enough to justify the superior ARP hardware to myself. If you do go ARP you'll be wanting to go for the D16Z6 Application, trust me on this one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
White smoke is burning coolant.
::thumbs::
Thats how I found out my ZC's head gasket was blown.. white puff of smoke when I started the car... it would go away after a few minutes, then it became progressively worse, and wouldn't keep a full thing of coolant in longer than 2 or 3 days.
::thumbs::
Not questioning your knowledge. Have you ever seen what happens when oil reaches a hot Cat............................................... ........white smoke. He's gonna have to replace the headgasket anyways if he takes it off to check it. But white smoke and oil coming out the tail pipe, I would think valve stem seals or maybe piston ring problem. There's ways to check(Cyl. leakage test, Compression test,etc.)before you start rifling parts at it.
Modified by shoemaker617 at 4:48 PM 3/26/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoemaker617 »</TD></TR><TR><TD CLASS="quote">There's ways to check(Cyl. leakage test, Compression test,etc.)before you start rifling parts at it.
Modified by shoemaker617 at 4:48 PM 3/26/2007</TD></TR></TABLE>
how do i do that?
also heard i need to get my head checked for warpage? is that true?
how do i do that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoemaker617 »</TD></TR><TR><TD CLASS="quote">Why are you replacing the head gasket????Sounds like you have a piston ring problem? How often do you have to top your oil up?</TD></TR></TABLE>
my oil level has been fine...
so i am going to replcae the head gasket and i mechanic i know told me i can just take a 16th of an inch off, or a thread off the bottom, and reuse them, he said hed rather do that then buy new ones, any words to that anybody?
in most cases you don't even need to replace the head bolts, they aren't torque to yeild like most other cars...Ive reused mine atleast 6 times, never had a problem with them..The only thing i do recomment is chasing the threads with a tap and die set
i just replaced my headgasket on my b16 and man, you might as well just bite the bullet and go ahead and get some arp headstuds. it would really suck if you go and replace the headgasket and then have to take it all apart to put new studs in. i know the stock honda bolts are torque to yield, so you are supposed to only use them once.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 »</TD></TR><TR><TD CLASS="quote">as well as about 95% of other cars are torque to yeild.</TD></TR></TABLE>
the dealer and several other people have informed me that honda headbolts are not torque to yeild
DrkHrse
54
Feb 10, 2013 03:55 AM
