92-95 transmission bolts the same as 88-91 transmission bolts?
I need some transmission bolts to mount my D16A6 on an engine stand. However, they don't have the bolts on http://www.slhonda.com anymore. Will the tranny bolts from a 92-95 work?
Here's the link. #14 is what I was looking at:
http://www.slhondaparts.com/br...=true
#14 Will not work. Those are for holding the two tranny case halves together = Much too small. You need to use Motor Mount Bolts; The longest ones. You can't even use the tranny -> Engine bolts with my engine stand.
Doesnt' matter. If you want to reuse them for another car, get one of each. Other wise just get 4 of the longest. You could always add washers as a spacer if it wound up being too long for your engine stand.
Tippyman
Mar 24, 2007 06:45 PM
jcarothers
Jun 2, 2004 09:59 PM
civicmatt
Nov 14, 2002 11:13 AM
