Difference in vtec and non-vtec timing gears?
Old Mar 24, 2007 | 02:33 PM
ky_urotrsh's Avatar
Default Difference in vtec and non-vtec timing gears?
I need to know about the cam and crank gears. Are they different offsets, sizes, or belt pitch?
thanks
Old Mar 24, 2007 | 02:34 PM
Padawan's Avatar
Darth ModerVader
Default Re: Difference in vtec and non-vtec timing gears? (ky_urotrsh)
B or D series?
Old Mar 24, 2007 | 11:29 PM
ky_urotrsh's Avatar
I'm not famaliar with Hondas, so I do not know the series. I'm doing a conversion on a 20v VW so that I can run dual timing gears. I have a cam gear from a '98 civic dx for reference. I was checking AEM's site and there were different parts numbers for vtec and non-vtec. Since I'm having to machine down either the gear or cam, I was trying to see if a vtec gear would work better for my application.
Old Mar 25, 2007 | 04:31 AM
Padawan's Avatar
Darth ModerVader
If you're referring strictly to the inner diameter of the centre bore, there is no difference.
Old Mar 25, 2007 | 07:09 AM
spork motorsports's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ky_urotrsh &raquo;</TD></TR><TR><TD CLASS="quote">I'm not famaliar with Hondas, so I do not know the series. I'm doing a conversion on a 20v VW so that I can run dual timing gears. I have a cam gear from a '98 civic dx for reference. I was checking AEM's site and there were different parts numbers for vtec and non-vtec. Since I'm having to machine down either the gear or cam, I was trying to see if a vtec gear would work better for my application.</TD></TR></TABLE>
for future reference you have a d16y7 non vtec camshaft gear and timing gear i have the oem one but it hink you want the aem one
why do you want 2 timing gears???? new to me
Old Mar 25, 2007 | 07:19 AM
92ehatch's Avatar
Default Re: Difference in vtec and non-vtec timing gears? (spork motorsports)
i think that the 92-95 gears are the exact same d series anyways
Old Mar 25, 2007 | 09:26 AM
* B A N N E D *
Default Re: Difference in vtec and non-vtec timing gears? (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">i think that the 92-95 gears are the exact same d series anyways</TD></TR></TABLE>
dont you have to advance the d16y8 gears 2 degree's if used on d16z6's? (aem tru time gears only)
Old Mar 26, 2007 | 12:43 AM
ky_urotrsh's Avatar
I want two external cam gears so that the cams can easily be adjusted independently. The only aftermarket solution is an adjustable timing chain gear. So with two external, I do not have to remove the valvecover to make adjustments on the intake cam.
Thanks for the info on the center bores, but I was also wondering if they have different offsets?
Flipimp1
Feb 27, 2010 01:33 PM
koa
Jun 10, 2007 12:21 PM
4DRmafia
Aug 14, 2006 09:53 PM
igo4bmx
Sep 13, 2005 01:53 PM
Civichatch27
Sep 24, 2004 02:04 PM
