stupid noob with camber kit in hand... plz help
Old Mar 24, 2007 | 09:31 AM
bacardiboi's Avatar
Default stupid noob with camber kit in hand... plz help
so rear camber adjustment kit... didnt come with instructions... and i figured it out... i think...
i installed them like this
o``o
but after i buttoned everything up i thought
"hey what if they were supposed to go like this?"
o__o
then i thought nah.. but i just saw stock suspension pics and the upper control arms look like o__o not o``o and im concerned... help????
Old Mar 24, 2007 | 10:04 AM
cambopheonix56's Avatar
Default Re: stupid noob with camber kit in hand... plz help (bacardiboi)
WTF? Pics? I have no clue what you are saying.
Old Mar 24, 2007 | 10:07 AM
jfruauff's Avatar
can you explain more what ___ and ``` means
Old Mar 24, 2007 | 10:11 AM
4drgsr96's Avatar
Default Re: stupid noob with camber kit in hand... plz help (jfruauff)
he means the rear upper control arms
Old Mar 24, 2007 | 10:12 AM
4drgsr96's Avatar
Default Re: stupid noob with camber kit in hand... plz help (4drgsr96)
and maybe you should install them the way you want to.
Old Mar 24, 2007 | 10:59 PM
bacardiboi's Avatar
ok see above how the adjustment barrel is offset from the bushings on each end...
laid flat on the table the profile could look like this
o__o barrel down
or like this
o``o barrel up
i intalled them as you see them on the picture, adjustment barrel on the topmost side...
but the stock upper control arms curve down on the top side, the main bulk is on the bottom side.
should i have installed them with the adjustment barrel (main bulk) on the bottom side???
Old Mar 25, 2007 | 10:53 AM
Default Re: (bacardiboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bacardiboi &raquo;</TD></TR><TR><TD CLASS="quote">ok see above how the adjustment barrel is offset from the bushings on each end...
o__o barrel down
or like this
o``o barrel up
should i have installed them with the adjustment barrel (main bulk) on the bottom side???</TD></TR></TABLE>
Pics dude. I don't know what o``o is and I installed my kit myself.
Old Mar 25, 2007 | 11:28 AM
4EN[sic]'s Avatar
Default Re: (cambopheonix56)
should not matter in the least. the mounting points are going to be the same distance apart no matter if one way or the other. Unless their is a clearance issue with something hitting it if it is one way? Should not matter unless you just think it looks stupid or something?
Chemi421
Suspension & Brakes
11
Aug 30, 2017 04:25 PM
stefanne3
Apr 11, 2007 06:57 PM
chihuahuamanx
Jun 18, 2004 06:05 PM
SilverIntegra
Nov 30, 2002 02:10 PM
