oem headlight question
Old Mar 24, 2007 | 08:52 AM
kylekjk38's Avatar
Default oem headlight question
is it possible to mod the oem headlights?
Old Mar 24, 2007 | 08:55 AM
RBaluca.com's Avatar
Default Re: oem headlight question (kylekjk38)
In what way?
If you want to paint them, yes you could.
Old Mar 24, 2007 | 08:56 AM
kylekjk38's Avatar
Default Re: oem headlight question (re-marquable)
yeah i wanted to paint the insides black. i saw glue around the casing, so i wasnt sure if it would go back together 100%
Old Mar 24, 2007 | 08:58 AM
kylekjk38's Avatar
my brother just did his subie headlights. he baked them, peeled them apart, painted then rebaked to put back together. was wondering if i can do the same
Old Mar 24, 2007 | 08:59 AM
Padawan's Avatar
Darth ModerVader
Default Re: (kylekjk38)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylekjk38 &raquo;</TD></TR><TR><TD CLASS="quote">my brother just did his subie headlights. he baked them, peeled them apart, painted then rebaked to put back together. was wondering if i can do the same</TD></TR></TABLE>
Yes, you can.
You should be able to find a few DIY's if you search a bit.
Old Mar 24, 2007 | 09:02 AM
kylekjk38's Avatar
ok i just found it, i couldn't find it right away. thanks man
Old Mar 24, 2007 | 09:49 AM
em1mata's Avatar
well this is what the last guy did, he put the unit in an oven for 10 Min's ant high temps. and the glue softened up.
Old Mar 24, 2007 | 11:35 AM
ukcoupe's Avatar
yeah i've done it on mine, jst make sure u dont leave it in ther too long! and be careful when taking off/putting back not 2 break the clips.
Old Mar 24, 2007 | 01:38 PM
Striker_1818's Avatar
and put some baking sheet under the headlight...
Old Mar 24, 2007 | 01:40 PM
Eran's Avatar
HT White Ops
Default Re: (Striker_1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 &raquo;</TD></TR><TR><TD CLASS="quote">and put some baking sheet under the headlight...</TD></TR></TABLE>
I always foil my baking sheet too, shiny side up so it disperses the heat instead of absorbing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1mata &raquo;</TD></TR><TR><TD CLASS="quote">well this is what the last guy did, he put the unit in an oven for 10 Min's ant high temps. and the glue softened up. </TD></TR></TABLE>
Nooooo.
I do 5 minute increments (I check every 5) at 225 degrees.
Old Mar 24, 2007 | 01:45 PM
Default Re: (Eran)
it depends what type of oven you're using...
generally turn theoven on at 300F for 5 mins
then turn it off put the bakin sheet on the bottom and place your headlight in...
leave it there for 10 mins(while the oven is off) and then with a philips screw driver pry it open
sd_ej1
Paint and Body
Jul 22, 2008 02:11 PM
iluvmy2000civicex
Jul 14, 2008 12:48 PM
daewonder.
Feb 3, 2007 10:10 AM
5lugSlug
Aug 14, 2005 05:05 PM
turboman
Jan 5, 2004 12:49 PM
