blown fuse for small interior
Old Mar 24, 2007 | 05:38 AM
noypi's Avatar
Default blown fuse for small interior
anyone have wiring diagram for small lights for 97 accord- my instrument cluster, taillamps and other exterior lights inop the fuse keeps going due to a short -need to find short or sticking relay
Old Mar 24, 2007 | 02:36 PM
Aahj's Avatar
Default Re: blown fuse for small interior (noypi)
The headlight switch is a known problem with that model accord. Just my .02 cents.
AJ
Old Mar 24, 2007 | 11:23 PM
ilovemydc5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noypi &raquo;</TD></TR><TR><TD CLASS="quote">anyone have wiring diagram for small lights for 97 accord- my instrument cluster, taillamps and other exterior lights inop the fuse keeps going due to a short -need to find short or sticking relay</TD></TR></TABLE>
Bro i had the same damn problem in my 96 like a couple days ago i put a 5" autometer tach in my car an it just kept blowing my small light right and left, it would work when i put it in then when i hit a bump it would blow, i changed out my gauge cluster and when i was putting my gauge cluster in i noticed my dimmer **** wire was showing so i taped it an it works fine now i hit bumps an it hasnt blowin yet so i will keep u post if it blows because i will be in the same boat as you bro.
Old Mar 25, 2007 | 05:38 AM
noypi's Avatar
thanks guys... found open wire on r/side turn signal-isolated the wire but still blowing. i'll try to add a ground on the light. will check the headlight switch today-thanks
Old Mar 25, 2007 | 08:14 AM
noypi's Avatar
well just took off the headlight switch -replace with my lude still blows anybody got etm on headlights- might need to rewire portion of body harness- now my throttle position sensor is coming on...thanks
Jun 10, 2013 01:11 PM
lilsicsoul
Mar 14, 2009 02:30 PM
silverboost
Jan 2, 2007 01:52 PM
buzlink
Dec 4, 2005 09:37 AM
mrbsponge
Dec 31, 2003 03:31 PM
