fuse keeps blowing
Old Aug 9, 2011 | 06:31 PM
(. )( .)'s Avatar
Default fuse keeps blowing
Sup peeps, I have a 96 dc4 rs, and my fuse keeps blowing, as soon as I put the fuse in, it pops. Its the instrument cluster/plate light/driving light 10a fuse. I checked My cluster, driving lights, plate lights and nothing seems to be wrong..thanks for any help
Old Aug 10, 2011 | 08:35 AM
(. )( .)'s Avatar
Default Re: fuse keeps blowing
anyone?
Old Aug 10, 2011 | 08:41 AM
Builda'Teg_92's Avatar
you got a short buddy.
Old Aug 10, 2011 | 08:50 AM
Dogginator's Avatar
Daisy... Daisy...
Pull out the wiring diagram and a multimeter and start isolating parts of the circuit until you find that short. Unfortunately, there is no easy answer for this.
Since the fuse blows as soon as you put it in, chances are that the problem is before the switch. (Is there a relay for these lights?)
Old Aug 10, 2011 | 12:40 PM
(. )( .)'s Avatar
I'm not sure if their is a relay for them :/ if so..possible Burns relay..
this sucks. I'm not good at electrical stuff, Even if i get a multimeter and a manual, i wouldn't know where to start..i did install an amp before this happened. it works perfect, can this cause this problem?
Old Aug 10, 2011 | 12:43 PM
Dogginator's Avatar
Daisy... Daisy...
Did it start immediately after the amp installation? Was a radio also installed? (The illumination would run from that circuit.)
Old Aug 10, 2011 | 12:53 PM
yeah i was gonna say start at areas you may have touched or things you have added, like a fan switch, radio, gauges ect. thats always the best place to start.
I also believe there is a relay if i remember, its really small. it goes together with your cluster harness (a small seperate harness)
Old Aug 10, 2011 | 01:41 PM
GagnarTheUnruly's Avatar
I had a similar problem -- shorted out the fuse protecting my head/taillights at night while on the Mass Pike.
I guessed that the problem was due to a short I made when I installed my stereo. I fiddled with the wires behind the stereo, tried to keep them away from anything grounded, and the problem was solved. No problems since (and I've since tidied up those connections a bit).
Old Aug 10, 2011 | 07:43 PM
(. )( .)'s Avatar
No, it blew a week after..that's what got me Confused, because if it was right after the install, it would be obvious haha
I wish i seen your guys post before i put in work on my car haha. I disconnected my stereo, and I tried again..nothing, I disconnected the 12v wire running to the amp, and all my lights work problem solved!
All the amp wiring was installed in my car before i bought it..now i need to find out how to successfully hook up the amp without shorting out..gotta find the short
Old Aug 10, 2011 | 10:17 PM
sc34dc4's Avatar
12v constant " run from the battery with an inline fuse.use proper gauge"
ground "any clean metal area. Keep ground wire under 12" and use proper gauge"
remote turn on "blue wire on back of radio harness straight to the amp"
Just re do the wiring and you should be fine.
Old Aug 11, 2011 | 03:08 AM
Robinjo's Avatar
Try removing your trunk light. I had a similar problem and the trunk light was shorting out, causing a fuse to keep blowing...
Old Aug 11, 2011 | 06:03 AM
fcm's Avatar
fcm
Old Fart
What was the amps power lead connected to, it should be the batt. pos.(+), is it not?
I would also check and see what the red/black lead in the stock radio harness is connected to, should be an orange lead on aftermarket HU if it has one, if not, the red/black lead should be isolated if not used, it is "illumination" if it shorts to ground the 10A "tail light" fuse will blow.
You also said, "fuse keeps blowing, as soon as I put the fuse in, it pops" is the park/head light switch on when you put the fuse in, or does it make a diff. if the switch is on or not? 94
Old Aug 11, 2011 | 09:15 AM
(. )( .)'s Avatar
you really know your stuff man, the red/black wire goes to an orange wire on the female connector, and the orange wire has exposed copper!!!! ill cap if off!!
the amp is connected proper, I've done it to all my other cars, but i trusted the wires that were already installed, were good to go..my fault..
I blew 2 fuses when the switch for the driving lights was on and off. it would just spark..fuse boxes for the win
ill rewire everything today, and update
Old Apr 18, 2013 | 11:54 PM
McCainiac's Avatar
Why must the ground be under 12"?
Old Apr 19, 2013 | 06:46 AM
fcm's Avatar
fcm
Old Fart
Old tread, but an amp ground should be as short as possible, as should any lead to the amp, the longer the lead the more resistance there is. 94
Old Jun 10, 2013 | 11:49 AM
Loyalhondahaver's Avatar
Icon7 Re: fuse keeps blowing
Sorry to bump an old thread but this may help someone.
I was having this issue (radio fuse blowing as soon as key turned (I) after radio installation, the issue turned out to be..There was a 20 amp fuse under the hood in the back up radio spot instead of (I believe) a ten. Good luck troubleshooters.
Old Jun 10, 2013 | 01:11 PM
3rdtimecharmer's Avatar
10 Year Member
FCM is the man. ive said it plenty of times and ill say it again .
my fuse keeps blowing because of a short in my turn signal wire. fixed it fast. hope u find ur problem
byc_cb7
Sep 28, 2009 02:45 PM
traxxasx
10
Aug 10, 2009 01:28 PM
ludesrv
Jun 26, 2007 08:03 AM
honda011
15
Nov 26, 2005 08:10 AM
I8ayellowcrayon
21
Sep 1, 2005 01:34 AM
