the smokeing......
Old Mar 24, 2007 | 05:13 AM
BukakkEK9's Avatar
Default the smokeing......
I have had a b18c motor in my 00 hatch for a while now and it has been all good for 8 months, and i have taken it to the track a couple times, as one should with thier weekend toy. well I made a pass and my buddy who i always go with knowticed i was smokeing pretty bad, so i let him run it a couple times in diffrent ways, and noted that even under full throttle it dosent smoke untill vtec comes on, and as soon as vtec comes on it starts smokeing, can anyone tell me what this could be? Bad valve seals/guides? piston rings even???
Old Mar 24, 2007 | 05:44 AM
alterdcreations's Avatar
Default Re: the smokeing...... (BukakkEK9)
is it black smoke... then your running rich
if its blue smoke then you need to do a compression test and a leak down test
Old Mar 24, 2007 | 06:24 AM
BukakkEK9's Avatar
the smoke isnt blue, it isnt black its just white, and it dosent smell like oil, it just smells like a really strong exhaust smell.
Old Mar 24, 2007 | 06:28 AM
mugeneghatchie's Avatar
could be your valve seals
Old Mar 24, 2007 | 06:48 AM
dbiker207's Avatar
Default Re: (mugeneghatchie)
valve seals would smoke under high rpm decell, when the engine is at high vacuum. not under wot when there is lik 1-0 inches of vacuum. do a compression/leak down its most likly the piston rings. if the compression/leak down test results r ok then check the pcv system for clogs. hope this helps
Old Mar 26, 2007 | 02:15 PM
sohctodohc's Avatar
Default Re: (dbiker207)
im gonna bump this back to the top cuz i have a b16a having the same exact problems and i changed the pvc thing and its still smokeing at high rpms. i burnt like a quart of oil in 1000miles so i need some answers.
Old Mar 26, 2007 | 04:29 PM
Default Re: (sohctodohc)
if your not running a cat then maybe your timing is off
Old Mar 27, 2007 | 02:14 PM
sohctodohc's Avatar
Default Re: (alterdcreations)
i have a cat on it. i dont know bout op.
LaOXXKIDD
Aug 15, 2009 12:05 PM
Redprelude98
30
Jul 21, 2009 01:21 PM
HybridBB6
May 14, 2007 02:36 PM
ek2k
May 25, 2005 01:17 PM
Terry_shum
May 1, 2004 05:50 PM
