b16 fan switch wiring
The guy i bought my rex from had the fan wired too a switch inside the car.it was all riced out and now its coming along.No i took off the switch and cut the wire from the switch.now i just have the plug for the fan and some wire.now where does this wire hook up too?Where does the wire for the fan coming from the bottom off the fan hook up too?Thanks
here is how it should be:
on the inside fender panel, just behind the passenger side headlight, is the cooling fan relay - the relay has 4 wires coming out of it - black, black with yellow stripe, blue and yellow with green stripe - the black is a ground wire - the black/yellow is power and runs from the relay to the fan and also splits off in the harness and runs to fuse #15 in the under dash fuse box - the blue runs from the relay to the fan - the yellow/green runs to the temperature contolled fan switch which is on the back of the block on the OBD0 engines, right by the oil filter, and also splits off and runs to the fan control in the ECU - the fan switch on the back of the block also has a black wire to ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">here is how it should be:
on the inside fender panel, just behind the passenger side headlight, is the cooling fan relay - the relay has 4 wires coming out of it - black, black with yellow stripe, blue and yellow with green stripe - the black is a ground wire - the black/yellow is power and runs from the relay to the fan and also splits off in the harness and runs to fuse #15 in the under dash fuse box - the blue runs from the relay to the fan - the yellow/green runs to the temperature contolled fan switch which is on the back of the block on the OBD0 engines, right by the oil filter, and also splits off and runs to the fan control in the ECU - the fan switch on the back of the block also has a black wire to ground </TD></TR></TABLE>
I have been looking for something like this. I am still having a problem though...I know what relay you are talking about, but I am alittle confused on everything. Here is a picture of my relays.
You can see a plug on the end of the harness...what did that go too? I thought it went to the fan but it doesnt bolt up. I can pull all the wires loose and really take alook at everything but it just doesnt look right to me. Anyways here is a picture of my plug that comes from my fan. Its not wired to anything and the wire colors do not match anything...
Sooooooooooooo do I just rewire it all up like you said or what? I dont know I am about to give up...
also there were two fans orginally...I am guessing one was for the AC and the other was just your normal fan...correct me if I am wrong...thats why I thought that wiring may have went to the fan for the AC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 »</TD></TR><TR><TD CLASS="quote">Does anyone know?</TD></TR></TABLE>
SteelcityLude
Aug 27, 2011 02:46 PM
90civichbsi
Mar 29, 2009 03:30 PM
