need advice for ls swap in 91 hatch
Old Mar 24, 2007 | 12:12 AM
bertsb18hatch's Avatar
Default need advice for ls swap in 91 hatch
I own a 91 civic hatch with a ls engine swap. The side motor mount bolts going into the block stripped out. I bought a complete new bottom end and installed it. I have heard from a few people that the reason my bolts stripped out, was because there was no front mount and with my motor torquing back and forth they ripped the threads out. I have seen some replacement front crossmembers that allow you to install a front motor mount. Has anybody had this problem? Can anyone give me any advice ?
Old Mar 24, 2007 | 05:59 PM
EF_LSVtec's Avatar
Default Re: need advice for ls swap in 91 hatch (bertsb18hatch)
The extra mount will help but if you tighten all 3 mounts the first time you wouldn't need to spend on a new crossmember.
Old Mar 24, 2007 | 08:35 PM
mr.speaker's Avatar
ALL of the aftermarket 3 piece mount kits are solid so there really isn't any movement at all unless the bushings are worn out..Are you sure the bolts were tightened down?
Old Mar 24, 2007 | 10:20 PM
Im not sure i bought the car from someone and now my mechanic is putting my new block in it and putting everything back together he said i should go that route i was just tyring to figure out what was best route to go. I drove car for a while then it messed up on me and sat for a while before i purchased a rebuilt bottom end. i have alot of vibration while driving and revving the engine does anyone know what this could be ? Im just relaly getting into the b-series into the 4th generation hatchs. Im trying to get somene elses input on it.
Old Mar 25, 2007 | 07:49 PM
EF_LSVtec's Avatar
What kind of mounts do you have? If they're solid or race mounts, the vibration is normal.
Old Mar 25, 2007 | 07:57 PM
Default Re: need advice for ls swap in 91 hatch (EF_LSVtec)
no they're not race or solid mounts, they are black with black bushings. im not sure the brand i didnt buy them, but my mechanic said he thought they were avid mounts.
Old Mar 25, 2007 | 08:01 PM
EF_LSVtec's Avatar
What kind of vibration and where? Dash?
Old Mar 25, 2007 | 08:04 PM
its lke a shaking vibration when im revving the engine. The dash shakes and u can feel it under your feet. The guy who had the car before me put a crx exhaust system on it, i dont know if maybe its too close to the floorborads and making it vibrate. the car wasnt put togetehr right it was half way done and now its in shop as we speak, being doen the right way. I only ave few days left until i get it back.
Old Mar 25, 2007 | 08:11 PM
EF_LSVtec's Avatar
I suppose you have to inspect the exhaust clearances for rubbing. I'm using hasport mounts and I get some vibrations but not like what you described. Just wait when the swap is done and inspect it again. Maybe it's because of the loose mounts..
Old Mar 25, 2007 | 08:14 PM
i was thinking the same thing ill know in a few days and post what it does. i also just posted a topic abot questions about lsvtec's if you could help.
Old Apr 6, 2007 | 10:00 PM
well the swap is done and i have the car back still alot of vibration, but my mechanic said my mounts are pretty worn so it is like having a solid mount. I will be purchasing some mounts soon to stop the vibration. does anyone have any suggestions on a mount kit to buy other than hasport, that has a good price?
Old Apr 6, 2007 | 10:12 PM
ramsay03's Avatar
make shure you get mount inserts they make a big difference i had worn mounts and when themotor touqued back the one time it pulled the shifter linkage out of the tranny and fucked it
frizzle
10
Dec 7, 2009 08:11 PM
thundernutz
Oct 31, 2009 03:34 PM
jdmthug
Oct 11, 2007 07:37 AM
ITR.#1446
May 3, 2005 11:05 AM
