Help looked...but can't figure....suspension tech. Sway bar!!
the ST bar is 7/8th inch. it isnt measured in mm. atleast mine was like that.
you will need the bracket that ties the bar to the rear lca/shock mounting point and all the brackets that tie it to the subframe. its a different set up then the stock swaybar set-up.
i decided that the st bars arent worth it to me and i ended up getting the comptech rear sway tie combo. my personal opinion. i just didnt like how it mounted and the design. dont get me wrong, it works great. just not my liking.
oh...i think i have the end links with it...i don't wanna throw these away..becuz i got a deal...with it..let's see if i could get pics......it' looks with red bushing and stuff
https://honda-tech.com/zerothread?id=1911636
thats a pic of some of the hardware. you need to search the archives casue its posted up in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziejoe775 »</TD></TR><TR><TD CLASS="quote">anybody know what type of st bar i have....there were 2 kind...</TD></TR></TABLE>
Man, you're stupid. That's a front swaybar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziejoe775 »</TD></TR><TR><TD CLASS="quote">help</TD></TR></TABLE>
I DID HELP YOU.
It's a front bar. Stop bumping your thread every thirty seconds and read it.
I DID HELP YOU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziejoe775 »</TD></TR><TR><TD CLASS="quote">oh.......i lost the paper works...okay...deng....it's a front swaybar....man...all that for nothing....now if i install it...will this be oversteer...or understeer?</TD></TR></TABLE>
Under.
Under.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziejoe775 »</TD></TR><TR><TD CLASS="quote">which....helps in what......cornering.....driving fastester drag....or what...</TD></TR></TABLE>
Do you know what a swaybar does?
wow.....taken straight from nasioc: "Larger sway bars have two main effects. They change the vehicle balance in terms of understeer or oversteer, and increase roll resistance. Both of these attributes can provide increased overall grip."
