overheating..
Old May 24, 2002 | 11:34 AM
verseone's Avatar
Default overheating..
i hope someone can help me...
my car is slightly overheating..the needle is reading over the half point.. i have a d16z6 in my crx and i just changed the coolant/water recently. Is it my thermostat? the car doesnt overheat all the way..i was wondering if it could be my radiator cap? My fan turns on, but its the a/c fan not the regular one....i havent had ac in my car since the swap. maybe someone can help..thanks
Old May 24, 2002 | 01:12 PM
Perfectionist's Avatar
Default Re: overheating.. (verseone)
You're saying this is happening since you changed the coolant, and was OK before? It's possible some crud broke loose and is clogging your T-stat. Might as well replace it if you're going to open it up. I recommend a Honda OEM stat if you do. Also, make sure there is no air in the system.
PeakBoostSi
Jul 7, 2007 03:27 PM
yz125rider21
11
Aug 9, 2006 04:42 PM
twenty
Jul 21, 2005 04:32 PM
coupon
Jul 21, 2005 10:42 AM
vinuneuro
Jun 22, 2005 10:16 PM
