needle calibration...where to get it done?
Old May 24, 2002 | 11:24 AM
uNF$@#!'s Avatar
Default needle calibration...where to get it done?
i just bought a cluster from a guy with indigay needles and he took off his needles to put on the indiglo faces on... and he messed up the speedometer...etc... its way off now
question is, who can calibrate these needles? I recall people saying its possible...i just called up acura and they said i'd have to buy a new guage cluster b/c they dont recalibrate...
TIA
Old May 24, 2002 | 11:51 AM
uNF$@#!'s Avatar
Default Re: needle calibration...where to get it done? (00-0187)
Old May 24, 2002 | 12:01 PM
01PYITR's Avatar
make you question clearer!
Old May 24, 2002 | 12:03 PM
uNF$@#!'s Avatar
Default Re: needle calibration...where to get it done? (01PYITR)
question is, who can calibrate the speedometer needles? It's reading about 10 off the actual speed. I recall people saying its possible...i just called up acura and they said i'd have to buy a new guage cluster b/c they dont recalibrate...
01PYITR's Avatar
Edit:
[Modified by 01PYITR, 4:07 PM 5/24/2002]
Old May 24, 2002 | 12:04 PM
BlueR's Avatar
Old May 24, 2002 | 12:05 PM
reefer_bob's Avatar
That's phat.
uNF$@#!'s Avatar
no. i still want to read things in MPH since the speed limits here are by mph.
norice's Avatar
Default Re: needle calibration...where to get it done? (reefer_bob)
Oh - it goes to 11!
Old May 24, 2002 | 12:10 PM
uNF$@#!'s Avatar
Old May 24, 2002 | 12:17 PM
uNF$@#!'s Avatar
no one knows?
Old May 24, 2002 | 12:24 PM
uNF$@#!'s Avatar
anyone????
Old May 24, 2002 | 12:25 PM
norice's Avatar
http://directory.google.com/Top/Recr...dometer_Repair/
There is usually a speedo calibration section in your local Yellow Pages. Not sure how it is listed though. You could call the DMV and ask them what calibration shops they know of.
Old May 24, 2002 | 12:26 PM
guyuenvy's Avatar
normally when it happens you just take off the face of the cluster and remove the needles and just read adjust them to make them the right setting
Old May 24, 2002 | 12:30 PM
ITR#00-1077's Avatar
Are the indiglos still on the gauge cluster or no....???
Old May 24, 2002 | 12:32 PM
uNF$@#!'s Avatar
Default Re: needle calibration...where to get it done? (ITR#00-1077)
no, you want them?
anyhow, i wish there was a better way than just to plug and pray?
Old May 24, 2002 | 02:03 PM
AK94GSR's Avatar
Do you have the stock needles then?? I put gauge faces on my girlfriends car(not indiglows) and the speedo is off by 10mph. All I did was have her drive next to me while I took the needle out and then put it back on at 60mph. Sounds kind of funny, but it worked. Set the cruise once the person tells you your at 60.
Old May 24, 2002 | 02:06 PM
norice's Avatar
Default Re: needle calibration...where to get it done? (AK94GSR)
Wowee - swapping needles at 60 mph.
I wonder if this 'recalibration' would work with the rpm gauge needle, which is incredibly innacurate? You would need some aftermarket gauge to calibrate from.
[Modified by norice, 3:06 PM 5/24/2002]
Old May 24, 2002 | 02:13 PM
B2FiNiTY's Avatar
Default Re: needle calibration...where to get it done? (norice)
Get a friend or buy a OBD scan tool, then you can get the accurate reading and adjust it. Be VERY carefull when removing the needles. They are fragile.
Old May 24, 2002 | 02:48 PM
The AntiRice's Avatar
Default Re: needle calibration...where to get it done? (B2FiNiTY)
kinda makes you wonder why he was selling the gauges in the firstplace, you shold just replace it, not worth the hassle, the guy dicked you...
Old May 24, 2002 | 02:55 PM
uNF$@#!'s Avatar
i have a vafc so the tach isnt the problem...its just the speedo which is off.... i tried to go out to a road, pace someone and mark that as 40...but then...people dont drive exactly on 40
mjcandy_2000
Aug 17, 2011 12:00 PM
integraturbo96
Aug 21, 2009 03:00 AM
funtak
Jul 13, 2007 08:12 PM
DCsports06
Feb 21, 2006 03:40 PM
explosive
Oct 21, 2003 10:14 AM
