d16z6 build
Old Mar 23, 2007 | 09:55 AM
Powered By D16Z6's Avatar
Default d16z6 build
I have a 94 civic si HB with a d16z6 engine that I am looking to build.
My goal is 300 horsepower. What I would like is so input on what setup I should use to reach this goal. Thank you
Old Mar 23, 2007 | 02:45 PM
Default Re: d16z6 build (Powered By D16Z6)
Would someone please leave a suggestion on what setup I could use on this build.
Thank you
Old Mar 23, 2007 | 05:44 PM
ExospeedAMcrx's Avatar
There are different options on how you can do it. We mainly do piston and rod upgrade or you can go the full build with a sleeved block with new pistons and rods. Make sure you at least upgrade the valvetrain so it can handle higher RPMs. So you can take advantage of higher RPM boost.
With the right combination of turbo size and a good block setup, you should be able to reach 300hp.
Old Mar 23, 2007 | 06:19 PM
BOOSTEd2's Avatar
you can use eagle rods, vitara pistons, zex cam, zex valvetrain and a nice size t3 or maybe even a t3/t4 with GOOD tuning to get there. not much is really needed. thats just a basic rundown.
Old Mar 23, 2007 | 07:05 PM
Is there anyone that have a d-series with this type of build. If so I would like to know how you went about it and what you would do different if you were to do it over?
Old Mar 23, 2007 | 07:09 PM
there are plenty of D16 builds on this forum. check the SEARCH function and you can find out the details on some members on here.
Wil
Exospeed Race Engines
Old Mar 23, 2007 | 07:19 PM
BOOSTEd2's Avatar
check out turbod16.com tons and tons of people there running similar setups
slob20ef
Apr 19, 2012 09:25 PM
Charger69
Apr 16, 2008 02:34 PM
mike93boost
Feb 27, 2006 08:18 PM
TurboEg
Aug 4, 2003 08:22 PM
