Boost on stock ITR rods
Type-R's hate boost. Why are you going to lower compression, that is the whole idea of the Type-R is to have high compression! If you were going to run boost why didn't you get a GSR.
Did you answer his question? no so STFU
To answer your question, I have ran 10 daily with no problems, but 8 is really where you would want to be. I drive 110 miles a day without any problems on the bottem end
[Modified by cetane, 11:43 AM 5/24/2002]
Right now im at about 5lbs. Everything is peechy keen, less the oil/exhaust leak which will be fixed this weekend.
yb-b0t: open dumptube from wastegate + spool + vtec = sounds like an atomic bomb.
Everything is stock internally right now. I honestly don't know what i'm making HP wise right but i'm guessing pretty close to 200? As for the work, i feel that the work put into building an NA setup for 200whp is just about as much labor as installing a turbo kit. As long as you aren't boost greedy and aren't stupid with how long you boost for, the motor should last with proper maintainence.
Its all in the tuning. Most common problem is cracking ringlands. I suggest talking to jinxproof he has built stock bottomed cars with lots of boost and it has held up. Proper fuel management is a must. Plus you need to respect the power the limits of your engine. There may still be posts of graphs with stock itrs boosted making around 280 to the wheels with nice torque. You may want to talk to SGT too he has experience with them.
IMHO, there is a large difference between turbo boost @ 10lbs and SC boost @ 10lbs. There is typically the difference of FMIC, and then the WIK for the S/C which *most*, not all, seem to lack in their setups.
eaxactly . the na ***** are back in effect
what a bunch of homos. im soo sick of hearing the r is too high comp for nitrous , for turbo , just leave it na . those are the people who are scared of fi .
If you are gonna tear your motor apart just to replace pistons, you might as well do the job right and get rods too.
Don't cut corners man, it doesn't pay off. Do it right the first time or don't do it at all.
