weight of s2k
~2800lbs curb weight depending upon fluid levels. SC'd 1/4 times are extremely variable. Esp. since most any one with an SC doesn't dare launch their S2000 out of fear of damaging the rear end of the car. Without modifying the rear end, these are track/autox cars, not dragsters.
? What makes the S2G's rear end so week or is it just to mutch power for it to handle a 4K clutchdump. What can be done to make it stronger any kits out there?
The GSR also has shorter axles, and doesn't come from the factory with a LSD. In addtion, a proper launch in an S2000 would use 6500rpm at the minimum. The car was in no way shape or form designed to perform drag launches.
can't handle a 4k clutch dump with a car that has a 9k rpm redline??? i dump the clutch at 5k easily on my gsr w/no problems..i dont' understand how it would damage the s2k.
GSR- Front wheel drive, on a lauch all weight is transferred to the rear of the car, which means less weight on the front tires... which results in wheel spin
S2K - Rear wheel drive, on a launch, weight is transferred to the rear tires, but since it is RWD, lots of stress on the driveline.
Its almost like doing a 4000rpm clutch dump into reverse with your gsr.... try it, you'll understand why still will break
coquinn
69
Jan 24, 2003 09:31 AM
