Honda S2000 Honda S2000
weight of s2k
Old May 24, 2002 | 10:05 AM
boostwhipped's Avatar
Default weight of s2k
interested in picking up an s2000, but i wanted to know the weight with full interior and et's with the comptech kit
any posts are appreciated
thanks
Old May 24, 2002 | 12:58 PM
jerrypeterson's Avatar
Default Re: weight of s2k (boostwhipped)
~2800lbs curb weight depending upon fluid levels. SC'd 1/4 times are extremely variable. Esp. since most any one with an SC doesn't dare launch their S2000 out of fear of damaging the rear end of the car. Without modifying the rear end, these are track/autox cars, not dragsters.
Old May 24, 2002 | 10:13 PM
underrated99si's Avatar
Default Re: weight of s2k (jerrypeterson)
? What makes the S2G's rear end so week or is it just to mutch power for it to handle a 4K clutchdump. What can be done to make it stronger any kits out there?
Old May 27, 2002 | 07:18 PM
redteg1's Avatar
Default Re: weight of s2k (underrated99si)
can't handle a 4k clutch dump with a car that has a 9k rpm redline??? i dump the clutch at 5k easily on my gsr w/no problems..i dont' understand how it would damage the s2k.
Old May 27, 2002 | 08:29 PM
coquinn's Avatar
Default Re: weight of s2k (redteg1)
Most S2000 owners are droping the clutch at 7000 - 8000 RPM. Anything lower than this will glaze the clutch (at least in an OEM situation).
Old May 29, 2002 | 10:15 AM
The GSR also has shorter axles, and doesn't come from the factory with a LSD. In addtion, a proper launch in an S2000 would use 6500rpm at the minimum. The car was in no way shape or form designed to perform drag launches.
Old Jun 1, 2002 | 09:22 PM
fredren's Avatar
GSR- Front wheel drive, on a lauch all weight is transferred to the rear of the car, which means less weight on the front tires... which results in wheel spin
S2K - Rear wheel drive, on a launch, weight is transferred to the rear tires, but since it is RWD, lots of stress on the driveline.
Its almost like doing a 4000rpm clutch dump into reverse with your gsr.... try it, you'll understand why still will break
Old Jun 1, 2002 | 10:41 PM
1996GsrVtec's Avatar
Default Re: weight of s2k (fredren)
are you drunk? Who the **** is launching any non awd car at 6K lol.Your just gonna ******* spin anything above 3,500
Old Jun 8, 2002 | 07:08 PM
Sime's Avatar
Default Re: weight of s2k (1996GsrVtec)
actually, the S2000 bogs down at 3500rpm. Even 5000 could call for a bog. If yo ureally want to launch the S2000, you have to drive it like you stole it.
Old Jun 9, 2002 | 03:16 PM
leechungsr's Avatar
okay, some people need to go back to superhonda..moron
jdmyo21
Honda S2000
14
Apr 13, 2009 07:59 AM
madlion
Honda S2000
34
Mar 12, 2007 07:18 PM
coquinn
69
Jan 24, 2003 09:31 AM
Veil_Side_
Honda S2000
May 27, 2002 10:38 PM
