my rpm goes up and down // need help please
Old Mar 22, 2007 | 08:11 PM
p3terson17's Avatar
Default my rpm goes up and down // need help please
i have a 92 integra ls and when ever i push my clutch in or the car is not in gear (not moving) my rpms goes up and down (revving) would anyone know what the problem might be ?? if yes please let me know
thankx
Old Mar 22, 2007 | 08:15 PM
Haleiwa-Brando's Avatar
Default Re: my rpm goes up and down // need help please (p3terson17)
Use the search button. You were instructed of this when you read the TOS policy.
Old Mar 22, 2007 | 10:28 PM
99Geeezer's Avatar
Check your Idle Air Control for starters.
Old Mar 23, 2007 | 02:32 PM
DAJunkie90's Avatar
may be a vacuum leak, check all of your lines!!
Old Mar 23, 2007 | 05:10 PM
p3terson17's Avatar
Default Re: my rpm goes up and down // need help please (DAJunkie90)
i checked all the that even got a bran new map senser but its still reving the only way i got it to stop was buy taking my throttle body cable off but now i have no power on low rpms and my engine light is on its really bad to drive with it revving because i got a stage 3 racing clutch so for now my throttle body is off but please someone help
i went to a mechanic but all he did was tell me my map senser was bad and screwed up my vaccum hoses and broke me speedometer cable so iam really **** and have no idea what to do
Old Mar 23, 2007 | 05:49 PM
p3terson17's Avatar
how can i tell if my Idle Air Control is bad ??
Old Mar 24, 2007 | 10:18 AM
iridehonda's Avatar
i changed the sensor too that wasnt the problem when i took it in for a diagnostics they found holes in both hoses to the radiator. did you lose heat also or is it just reving by itself.
Old Mar 24, 2007 | 10:23 AM
iridehonda's Avatar
Go up to like auto zone or something and see if its throwing codes. Before i got the hoses changed it was saying that 1 3 4 were miss firing. so
Old Mar 24, 2007 | 10:28 AM
qwk db8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAJunkie90 &raquo;</TD></TR><TR><TD CLASS="quote">may be a vacuum leak, check all of your lines!!</TD></TR></TABLE>
Old Mar 24, 2007 | 10:36 AM
maxboost_50psi's Avatar
vacum leak
Old Mar 24, 2007 | 01:32 PM
p3terson17's Avatar
Default Re: my rpm goes up and down // need help please (iridehonda)
okay iam taking my car to a mechanic on mon also i wanted to know how can i tell if my integra is a jdm integra r not because the guy i bought it from said it was but iam not really sure ??? thankx
Old Mar 31, 2007 | 12:27 PM
wayne577's Avatar
check ur idle control sensor
Old Mar 31, 2007 | 01:03 PM
mike5809's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3terson17 &raquo;</TD></TR><TR><TD CLASS="quote">also i wanted to know how can i tell if my integra is a jdm integra r not because the guy i bought it from said it was but iam not really sure ??? thankx </TD></TR></TABLE>
What do you want to know, if the motor is a jdm motor? or what? The only way the car is a "JDM" is if its an XSi which it isn't as you stated its an LS.
The guy prolly stated its "JDM" as he prolly put one or two parts on here or there.
Old Mar 31, 2007 | 01:32 PM
bokals's Avatar
Default Re: my rpm goes up and down // need help please (mike5809)
check your FITV, IAVC
Gemar
16
Apr 11, 2013 07:58 PM
19_hatch_93
Nov 23, 2008 07:08 PM
danielfleenor
Apr 10, 2008 05:16 PM
civicEXtreme
Jan 12, 2006 07:20 AM
douboi
13
Oct 15, 2004 09:16 PM
