still a problem!!!!!
Old Mar 22, 2007 | 06:06 PM
themex77's Avatar
Default still a problem!!!!!
i checked if my spark plugs were working by disconnecting my wires while the car was on. the rpms droped on all of them but the #1 cylinder. it stayed the same even when i disconnected the spark plug wire? the #1 plug does spark and i think all my injectors are working could it be that power is not reaching the #1 injector?
thanks
Old Mar 22, 2007 | 06:52 PM
C_R_X_V_T_E_C's Avatar
Default Re: still a problem!!!!! (themex77)
do a compression check
Old Mar 22, 2007 | 07:14 PM
01d17's Avatar
Default Re: still a problem!!!!! (C_R_X_V_T_E_C)
did you check and see if its the spark plug wire that is bad by switching it with a working cylinder?
Old Mar 22, 2007 | 07:41 PM
themex77's Avatar
195 all across the board
if my wire is passing current shouldnt it be fine i have 8.5 msd wires
Old Mar 23, 2007 | 05:48 PM
themex77's Avatar
any 1
should i take a to a mechanic?
Old Mar 23, 2007 | 06:36 PM
higgunscrx's Avatar
swap the spark plug out if you are getting current to the wire then it must be the plug itself
Old Mar 25, 2007 | 08:34 PM
themex77's Avatar
Default Re: (higgunscrx)
well i dont think its the spark plug because i put in one of my old spark plugs and it did the samething? thanks 4 da input though
Old Mar 27, 2007 | 08:41 PM
themex77's Avatar
Default Re: (themex77)
bump
Svell
Mar 31, 2011 12:57 PM
ss85510
11
Oct 2, 2010 09:42 AM
nix94delsol
May 18, 2009 12:41 PM
banginryder16
Nov 23, 2007 06:32 AM
eseries07
Honda Civic (2001 - 2005)
Oct 26, 2006 11:28 AM
