fuel psi/boost cartech fmu question
Old Mar 22, 2007 | 05:37 PM
imskatencrzy's Avatar
Default fuel psi/boost cartech fmu question
hey guys.
im working on my first turbo honda. so all you guru's out there don't make me feel like an ***. im running a cartech fmu 2025 in a 1993 civic ex with a lsvtec swap max boost is only 7psi. the cartech fellas say that your pump needs to be capable of 95 MAXIMUM psi to handle 7-8 psi of boost. b16 injectors. factory fuel pump. my buddy has had several boosted hondas and said my pump and injectors will be fine but eventually i should upgrade. i need to get some feedback before i expletive my motor. thanks.
Old Mar 22, 2007 | 07:10 PM
tony413's Avatar
you wont find love for any type of FMU on this site unfortunately your gonna get the praise of hondata, chrome, and uberdata. now to answer your question you should be fine all stock for 7PSI if you wanna grow later you will need to up your injectors to 440cc they are common and popular and work. also are you planning on building the motor if so get a walbro pump to be safe . hope i helped
Type-X
Apr 6, 2005 05:37 AM
spl_nut
Apr 13, 2003 10:10 PM
SGR Teg
May 20, 2002 06:17 AM
89hybrid
Oct 11, 2001 12:30 PM
