Car wont start after swap! (searched)
Ok i found nothing useful in the search, but i swaped my ef sedan with a ls/vtec and ive checked all my grounds, set everything to TDC all my wiring is fine, my injectors are spraying, im getting spark, all my fuses are good, and i am outta ideas of what it could be! I had XdicktonesX come by and check everything and he couldnt figure it out. he told my it might be my compression, i havent checked that yet cause im tryna find a tester but does anyone have any suggestions, or anything how i can get this damn thing started
alright, so when you are cranking the engine over you are getting any "pops" from the exhaust? I am thinking you ignition timing is off. Most of the time what i do when major work has been done is loosen off the bolts on the distributor. Get someone to crank the engine over and you slowly turn the distributor until engine starts. I am only going to recommend to you that you try this only if the engine is popping randomly this it has sparked. If this has worked for you to get the car started set ignition timing with a timing gun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1TurboHatch »</TD></TR><TR><TD CLASS="quote">How would pulling the plug out to tell you if you had spark? You would either need to use the screwdriver method or use a spark tester.</TD></TR></TABLE>
take the plug wire off, put it next to metal, and watch it spark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arc_55 »</TD></TR><TR><TD CLASS="quote">alright, so when you are cranking the engine over you are getting any "pops" from the exhaust? I am thinking you ignition timing is off. Most of the time what i do when major work has been done is loosen off the bolts on the distributor. Get someone to crank the engine over and you slowly turn the distributor until engine starts. I am only going to recommend to you that you try this only if the engine is popping randomly this it has sparked. If this has worked for you to get the car started set ignition timing with a timing gun.</TD></TR></TABLE>
I tried that and it didnt work
, so yesterday i went and reset my pistons and cams at TDC, I had this guy that used to be a mechanic over yesterday and he told me that it could be my valve adjustment.
O and there is no "poping noise" when i try and crank it
, so yesterday i went and reset my pistons and cams at TDC, I had this guy that used to be a mechanic over yesterday and he told me that it could be my valve adjustment.O and there is no "poping noise" when i try and crank it
sounds like an ignition issue forsure if your not getting any popping or any signs that the fuel is igniting in the cylinder, thats whhy i said "popping" noise. Start at the basics again.... fuel,spark,air
Luke 91 ef
Jan 24, 2013 10:40 AM
marcusgnf
32
May 6, 2008 11:19 AM
jury
Jan 1, 2007 10:57 AM
EGNA
Jul 12, 2006 03:31 PM
