b20 ecu question
Old Mar 22, 2007 | 10:38 AM
iloveb16's Avatar
Default b20 ecu question
Just ordered a b20 from password using the b16 tranny from my last motor, to run stock b20 no vtec head nothing special what ecu should i use ? does stock work, and this is going into my eg hatch
Old Mar 25, 2007 | 03:55 PM
Tomdata's Avatar
Default Re: b20 ecu question (iloveb16)
you can use a stock P75 (OBD1 LS ecu) and the car should run pretty good. or you can get a P05 or P06 or P75 and get it chipped for a B20 and the car should rip.
I can chip the ecu for you so lemme know if I can be of service
Old Mar 25, 2007 | 07:07 PM
iloveb16's Avatar
Default Re: b20 ecu question (Tomdata)
will do man the motor is sitting in my car just on mounts so were trying to get her done asap
Old Mar 26, 2007 | 07:25 AM
mmuller's Avatar
Mad Scientist
the thing is that there is no publicly available base map for a b20 on obd1 since it was always an obd2 cade and the coding and bla bla.
you can start with a p75 but youll have to add fuel or your run lean and youll have to add timing because the bigger bore needs more
Old Mar 27, 2007 | 04:53 PM
Tomdata's Avatar
Default Re: b20 ecu question (mmuller)
fyi... I just tuned a guys car about three weeks ago with a stock b20 with stock fuel injectors and a stock fuel pressure regulator, so as long as your motor doesn't have any mods if I give you a copy of the program from that guys car yours should be good to go.
Old Mar 27, 2007 | 08:54 PM
SMOOTHN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomdata &raquo;</TD></TR><TR><TD CLASS="quote">fyi... I just tuned a guys car about three weeks ago with a stock b20 with stock fuel injectors and a stock fuel pressure regulator, so as long as your motor doesn't have any mods if I give you a copy of the program from that guys car yours should be good to go.</TD></TR></TABLE>
hey i did this b20 swap to obd1... it keeps dying me after about 10 min... will this program your talking about help me out?
Old Mar 27, 2007 | 11:14 PM
mtber's Avatar
Default Re: b20 ecu question (SMOOTHN)
Get a chipped ecu
Old Mar 28, 2007 | 08:04 PM
Tomdata's Avatar
Default Re: b20 ecu question (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMOOTHN &raquo;</TD></TR><TR><TD CLASS="quote">hey i did this b20 swap to obd1... it keeps dying me after about 10 min... will this program your talking about help me out?</TD></TR></TABLE>
programs are not cures to problems. all they are is calibrations for specific engine parameters. so I doubt any program will fix a random stalling problem, that is unless the car is stalling from suddenly going very lean (which still probably isnt the tune). what ecu do you have and has it been chipped yet?
allmotorCRX.
13
Jun 12, 2011 06:46 PM
91CRX-T
Apr 28, 2011 06:45 AM
rexracer626
Jun 24, 2010 06:28 AM
93redeghatch
Mar 24, 2010 11:43 AM
