Doing a Wire Tuck. Needing help!
Old Mar 22, 2007 | 07:10 AM
harmonator84's Avatar
Default Doing a Wire Tuck. Needing help!
Ok, I am in the middle of a wire tuck and I have came across some problems. I have some wires that went to nothing. Now I thought this was normal because its a b18a into a crx and there is probably going to be wires that are not needed. So I have taken some pictures in hope that you guys can help me out.
First problem I have having is with my fan, its not hook up. Now I know that it is supposed to be hooked up on the back of the block, but where. I crawled up under the car and took a look at the back of the block and this is pretty much the only spot I could find. Is this where it goes? If not what is that and why isnt it being used? If so do I just hook 1 wire up to one side and another wire up to the other?
Heres the picture of what I am talking about.
Its right next to the oil filter
close up
Now there is abunch more questions that I have but I dont have good pictures to show what I am talking about so I will ask more later. I will just edit this page. Thanks alot guys
Old Mar 22, 2007 | 07:16 AM
crx_si-r's Avatar
Default Re: Doing a Wire Tuck. Needing help! (harmonator84)
yes that is ur fan switch. if u want u could find a thermastat housing from an obd1 LS and us the switch from there, cuz from the looks of it, ur plug isnt gonna hold up to well. just a thought, or replace the sensor.
Old Mar 22, 2007 | 07:29 AM
Default Re: Doing a Wire Tuck. Needing help! (crx_si-r)
Ok, so there are no junk yard to get a part like that. Would that plug/ sensor be the same on my 89 Hf or 88 Dx. If so I will just grab that off of them. If not can I order it from like advance or something. What would all that be called that I need.
Old Mar 22, 2007 | 07:44 AM
Would this be what I need?
http://www.partsamerica.com/Pr...Set=A
Old Mar 22, 2007 | 08:23 AM
wickedEFguy's Avatar
Wait a min what is that extra green plug for?
My fan switch on my 1st gen B16 looks like this
#23 = fan switch
Old Mar 22, 2007 | 08:35 AM
Default Re: Doing a Wire Tuck. Needing help! (wickedEFguy)
Just found this on a 91 Integra and 93 GSR
#31 37760-PM3-003 SWITCH ASSY., THERMO (A-93)
#32 37773-PR4-A01 SENSOR, THERMO (A-108)
Ok now I'm confused because my B16 doesn't have that green plug. What does that other switch do?
Old Mar 22, 2007 | 09:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">
Ok now I'm confused because my B16 doesn't have that green plug. What does that other switch do?</TD></TR></TABLE>
OK, I just got back from my other cars. I am still kinda confused too. I dont know what that green plug is. Everything I find for the thermo looks like...well that link I have up there. I dont think the green plug goes for my fan. IDK, is there anyone out there that can shed some light on this?
Old Mar 22, 2007 | 10:36 AM
Well after looking at the wires I see its not the plug I showed you guys. To hook up my fan has to be the thing that has the prongs bent. I wonder if I just connect the wires to it if it will work or not. Since nobody has the answer I guess I have to find out the old fashion way by doing it myself.
Old Mar 22, 2007 | 02:00 PM
Wow nobody knows the answer to this...and where can I find that link that guy used. On hondaautomotiveparts.com it doesnt include the integra.
Old Mar 22, 2007 | 02:11 PM
jchung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">Just found this on a 91 Integra and 93 GSR
according to this is picture it looks like its #29 or #31.
Old Mar 22, 2007 | 03:16 PM
Default Re: Doing a Wire Tuck. Needing help! (jchung)
Ok, I still dont understand..
I am just going to burn my car down so I dont have to worry about it anymore.
Old Mar 22, 2007 | 05:20 PM
Well I have the answer.
The big green plug that is bent is the "engine oil temp switch"
something not used often on obd0 cars...and the one on the top right is the oil pressure sensor, and the dark green one on the top is the fan switch.
Now on to the wire tuck.
Egreyes
Apr 27, 2009 06:49 PM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
honda06si
14
Nov 3, 2004 08:37 AM
AussieK24
May 29, 2002 06:26 AM
Pro-Lude
Aug 22, 2001 08:41 PM
