engine light
Old Mar 22, 2007 | 05:20 AM
rivoe302er's Avatar
Default engine light
i just installed my rh and two days after my light came on how can i take it off
Old Mar 22, 2007 | 09:11 AM
bryce-o's Avatar
Default Re: engine light (rivoe302er)
pick up an oxygen sim and install it on the secondary o2 port. wotm.com sells a megan racing one for $16. you'll have to take your car in to reset the ecu once you install the o2 sim.
Old Mar 22, 2007 | 05:03 PM
Aco512's Avatar
yeah
you need a defouler
you can get them for cheap
Old Mar 22, 2007 | 06:23 PM
Rev4Ever's Avatar
Default Re: (Aco512)
I had it on my Spec-V and it works flawless. The brand is called "STOP." It's easy to make.
Old Mar 22, 2007 | 06:38 PM
HBK_DAVIDDD's Avatar
Default Re: engine light (bryce-o)
[QUOTE=bryce-o]pick up an oxygen sim and install it on the secondary o2 port. wotm.com sells a megan racing one for $16. you'll have to take your car in to reset the ecu once you install the o2 sim.[/QUOTE
after installing the o2 extension, to reset the ecu, pull the ecu fuse (in the engine bay) out for a little bit then push it back in and KABLAMO! problem gone
Old Mar 22, 2007 | 07:31 PM
jdmblu3s's Avatar
Default Re: engine light (WAGOM4N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAGOM4N &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=bryce-o]pick up an oxygen sim and install it on the secondary o2 port. wotm.com sells a megan racing one for $16. you'll have to take your car in to reset the ecu once you install the o2 sim.[/QUOTE
after installing the o2 extension, to reset the ecu, pull the ecu fuse (in the engine bay) out for a little bit then push it back in and KABLAMO! problem gone </TD></TR></TABLE>
is that safe...?jus wonderin cuz imma get headers soon.
Old Mar 22, 2007 | 08:33 PM
Rev4Ever's Avatar
Default Re: engine light (jdmblu3s)
Yeah, it's 110% safe I had it on my past car.
Old Mar 24, 2007 | 03:38 PM
rivoe302er's Avatar
can i get them at a speedshop?
hndacord02
Jan 18, 2006 12:02 PM
HONDA RR
Sep 16, 2005 03:53 PM
vtekstorm
Nov 15, 2004 05:56 PM
LAKER HATER
Nov 4, 2004 01:17 PM
vladd
Feb 18, 2004 02:12 PM
