Removing valve seals ?
Old Mar 21, 2007 | 08:42 PM
lude98SH's Avatar
Default Removing valve seals ?
I have the snap on pliers to remove them but they are still a PITA. I got a few of them but its real hard to get them off. Any tips ??
Old Mar 21, 2007 | 09:20 PM
Hawkze_2.3's Avatar
Default Re: Removing valve seals ? (lude98SH)
***How-To*** Install Valve Springs & Valve Stem Seals
https://honda-tech.com/zerothread/1604753
That might help
Old Mar 21, 2007 | 09:32 PM
lude98SH's Avatar
Default Re: Removing valve seals ? (Hawkze_2.3)
thanks but ive read that a few times actually. It doesnt really say anything new. Im wiggling them back and forth and pulling up slightly they dont want to move. One the head of the seal actually ripped off before it wanted to move.
Old Mar 21, 2007 | 09:37 PM
SnlpeR's Avatar
theyre designed to break (the rubber seals) when you remove them
so just muscle them out
pull upwards hard while yo wiggle them in weird angles
Old Jul 25, 2007 | 08:39 PM
boosted97civic's Avatar
Default Re: (SnlpeR)
awesome writeup
Old Jul 25, 2007 | 09:05 PM
turtleman321's Avatar
the are a bitch. just beast the **** out of them with some needle nose vice grips. that was the hardest part of my rebuild i think.
Old Jul 25, 2007 | 09:39 PM
vinuneuro's Avatar
Default Re: (turtleman321)
Crap! I'm doing my valve seals this weekend and was planning on just using regular pliers. Is it really that bad?
Btw, what valve spring compressor are you using?
Old Jul 26, 2007 | 05:35 AM
lude98SH's Avatar
Default Re: (vinuneuro)
i used the snap on overhead one. Also recently i removed the seals from 2 heads i had and when i used a heat gun on them they came off fairly easy. It still took alittle time however it worked very well. I just heat the seal until i saw it smoke alittle then pulled on it. If it didnt come out after a minute or 2 of trying i heated it again and then tried again.
Old Jul 26, 2007 | 05:39 AM
street_ride14's Avatar
Yup, the hardest part of my Cylinder head disassembly.
live4soccer7
17
Jul 1, 2019 06:44 AM
Dxs
Jun 12, 2008 09:29 PM
WhiteNess
Nov 7, 2005 05:04 AM
00b18b
Nov 21, 2003 11:08 AM
Space Boy
May 30, 2002 12:46 AM
