Need quick answer, cam seals?
Old Mar 21, 2007 | 03:39 PM
guymosiris's Avatar
Default Need quick answer, cam seals?
I'm replacing the cam seals (behind the cam gears), do they need hondabond, or do they just slide on and thats it?
I imagine hondabond would "stick" them to the end cap, making them not turn with the cam. But do they need to turn with the cam?
Old Mar 21, 2007 | 03:54 PM
onepoint6i's Avatar
Default Re: Need quick answer, cam seals? (guymosiris)
honda bond wouldnt hurt, but really they dont need it...you only need hondabond at the corners of the cams caps..
Old Mar 21, 2007 | 04:01 PM
guymosiris's Avatar
Default Re: Need quick answer, cam seals? (onepoint6i)
Thanks
Old Mar 21, 2007 | 08:44 PM
SlowReaction's Avatar
Sorry to tell you this but those seals arnt going to just "slide" in. Your going to have to take the cam covers and caps off to install them properly. You use a little bit a grey sealant on the outer edge of the cam seal.
Old Mar 21, 2007 | 08:57 PM
guymosiris's Avatar
Default Re: Need quick answer, cam seals? (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to tell you this but those seals arnt going to just "slide" in. Your going to have to take the cam covers and caps off to install them properly. You use a little bit a grey sealant on the outer edge of the cam seal.</TD></TR></TABLE>
I know. The timing belt was off, gears were off, cam caps and rails were off, took the cams in my hand and just slid them right on. Then I just needed to know if there should be hondabond/grey sealant on the outter side of the cam seals, but I didnt use any. Already put everything back together and she started fine.
Old Mar 22, 2007 | 07:19 AM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guymosiris &raquo;</TD></TR><TR><TD CLASS="quote">Thanks </TD></TR></TABLE>
djnikko
Feb 24, 2006 09:09 AM
asubennett
15
Jul 9, 2005 03:05 PM
integmester
Apr 18, 2005 12:34 PM
BlkSIvic
Feb 16, 2005 07:43 AM
whitelightning
Jan 17, 2003 08:07 AM
