ZC-no spark
I got no spark! Swapped on a distributor cap and I think that is the problem. We have absolutely no spark. What distributor cap is compatible, what distributor (whole thing) is compatable, and what rotor is compatable. Thanks!
-Dustin
-Dustin
are you throwing a code?look and see. it could be a 4 or a 8.its a cylinder position sensor,ignitor,crank angle sensor,or top dead center sensor.all are in your distrib.on the exhaust cam of the zc there is a sensor.its a cps or crank angle sensor.
check codes and go from there.
when i got my zc my distributor was bad and i didn't throw any codes. i got a new rotor and cap and checked all my wires. you can use 88-89 integra parts for your distributor. good luck.
JT2MA71
Apr 5, 2007 10:50 PM
SI_niki
Jun 15, 2004 07:54 AM
