Still fuel mani issues....race sunday....car still wont run right....help!!!
Here is the situation. I changed the vtec point in my CROME map a couple nights ago. Burned the map and now the car wont run (runs but really hard and sounds like its missing...keep reading). This map was run last year before winter and a few times through the winter. I did not change any values in the map, just saved the new vtec point and finished. No dice.
So I was thinking it was either the chip of ECU. I burned my old uberdata map (not tuned for some new goodies so I cant run it, but I can use it to idle). Car idles fine on the uber map so I know its not the ECU or Chip.
Im guessing its in Crome somewhere? I have reinstalled CROME a few times. For some reason crome wont let me burn my chips in program. Test runs ok, then hit "put on" and says "failed to connect".
Using a p28 on a crome (1.2) map tuned by myself.
Any ideas? Id like to run this weekend but need to car to run again lol. Ill be happy to send my map to anyone that thinks it might be the problem but I dont think it is.
chrome is retarded on ocasion for me. sometimes ill take a map and make a couple changes and the car wont run. go back to that same map and make the same changes again but slightly diff then last time and it work like a charm. i have no idea why it does this though.
not sure if you already covered this , but did you save before burning? If you don't it'll sputter and not want to start.
yeah i saved it. In crome it wont let me use the programmer so I have to use burn1 still. When I try to burn it in crome its says it like times out or something. But when I test the connection it says its fine.
crap? Id say its far from crap.... 99% of the people runnin crome have NEVER had a problem with it...I am one of them..
i had LOTS of problems with uberdata though, thats why i switched
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">crap? Id say its far from crap.... 99% of the people runnin crome have NEVER had a problem with it...I am one of them..
i had LOTS of problems with uberdata though, thats why i switched</TD></TR></TABLE>
Im tired of the bugs. Burn one map doesnt work, burn it again and it works. yeah Crome is better than uber but they both have their flaws. Worked good for a while now it doesnt want to work, just tired of it.
