why is my car running rich???
because unless you have a wideband o2 sensor and gauge, the a/f gauge you have is worthless and should not be trusted for any sort of diagnostics.
i got a b16 block, type r head titatium springs and retainers.. skunk2 manifold intake and exhaust....and yes im getten bad gas mileage.
Yea with out a wide-band there is really no way of telling what your a/r is at. Some questions:
1. is the check engine light on?
2. if so what is the code.
somethings that can cause a engine to run rich.
3. PCV valve?(shake it if it rattles ur okay
4. Incorrect ignition timing.
5. bad injector( can hold pressure)
6. Need a tune(with the mods done it needs a tune)
7. what computer are u running?
I'm not saying that this is ur problem but just an example of one situation.
On my local forum a member had bought an h22a1 and swapped it and what not. He later then replied saying that its running rich and that there's a check engine light on. Also he said that at idle it runs very rich and then when he punches it, it bogs down or what i said lose pretty much all power. So then I asked him if he knew what the code was. he had no idea. He checked the code and it was #7 TPS so i asked who did the wiring hes said he had some one do it. So then i told him to test his tps sensor. So the outcome of his problem was that his tps was wired backwards. So at idle it was reading like 5 volts so the ecu thinks its at WOT dumping fuel in. therefor when he accelerates the tps reads .45v and thinks its at idle no fuel
. but after that it ran fine.
Oh also check fuel pressure. and test ur O2 sensor. Just thought id give a lil help. Hope everything works out for ya. If not tuned its probably a good idea to do so.
Peace
. but after that it ran fine. Oh also check fuel pressure. and test ur O2 sensor. Just thought id give a lil help. Hope everything works out for ya. If not tuned its probably a good idea to do so.
Peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krytykalintentions »</TD></TR><TR><TD CLASS="quote">i have no CEL...and im running a p28 ECU..let me no wat u think</TD></TR></TABLE>
o2 sensors can be going bad with no CEL showing,
It will run rich, and in turn causing worse gas mileage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec_Dude »</TD></TR><TR><TD CLASS="quote">i'm guessing you running a chipped p28? if so, those ecu's generally have your car running rich, depending on what type of program it has.</TD></TR></TABLE>
There is your problem. Usually those chipped ecu make you run rich for no reason. Try to tune your car so it runs right.
majrneo
Aug 7, 2009 09:06 PM
Fatty_1775
Aug 15, 2005 04:01 PM
