S/T rear sway bar
Old Mar 21, 2007 | 07:57 AM
ef9ontime's Avatar
Default S/T rear sway bar
I was searching along in the archives, and could not find an answer to my question. I was looking to get some answers as to what setting would be good to run. The S/T rear bar has three holes for the links to bolt up to.Right now my car is sitting on koni yellows w/ h&r sport springs, da front knuckles w/ civic uca's, stock front sway bar. I am also replacing my rear trailing arm bushings with some nice oem ones. This car will be daily driven in the summer, and see the track once or twice.. Just lookin for some opinions before I go and put these parts on in a week.... thanks...
Old Mar 21, 2007 | 08:02 AM
89efDUSTY's Avatar
Default Re: S/T rear sway bar (ef9ontime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9ontime &raquo;</TD></TR><TR><TD CLASS="quote">I was searching along in the archives, and could not find an answer to my question. I was looking to get some answers as to what setting would be good to run. The S/T rear bar has three holes for the links to bolt up to.Right now my car is sitting on koni yellows w/ h&r sport springs, da front knuckles w/ civic uca's, stock front sway bar. I am also replacing my rear trailing arm bushings with some nice oem ones. This car will be daily driven in the summer, and see the track once or twice.. Just lookin for some opinions before I go and put these parts on in a week.... thanks... </TD></TR></TABLE> is there no tech in this, or am i illiterate ...what is your question or ??? im confused
Old Mar 21, 2007 | 09:55 AM
ef9ontime's Avatar
Default Re: S/T rear sway bar (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> is there no tech in this, or am i illiterate ...what is your question or ??? im confused</TD></TR></TABLE>
Well I asked a question.. let me rephrase that: Is there anyone is running a S/T rear sway bar? _really? What setting are you using?? (Theres 3 holes on the end of the sway bar) I would like to know because this is my daily driver..... is that better..?
Old Mar 21, 2007 | 09:59 AM
89efDUSTY's Avatar
I have an ST bar on my rex with AGX and GC... i use stiffest setting on shock, tires "SI 99-00" about 1/2 inch from top of wheel well trim "so thats how low" and closest hole towards center of the bar with it mounted to the shocks on the higher hole in the bracket...but thats me...opinion doesnt matter, try what you want and see if you like it, and my car is my DD as well
Old Mar 21, 2007 | 03:37 PM
EF_LSVtec's Avatar
Yeah, that's kinda like a "test and tune" as you go...I have mine set in the middle but I have adjustable camber, wider front tires etc...
Old Mar 21, 2007 | 06:23 PM
661rex89si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">I have an ST bar on my rex with AGX and GC... i use stiffest setting on shock, tires "SI 99-00" about 1/2 inch from top of wheel well trim "so thats how low" and closest hole towards center of the bar with it mounted to the shocks on the higher hole in the bracket...but thats me...opinion doesnt matter, try what you want and see if you like it, and my car is my DD as well </TD></TR></TABLE>
X2 very true
99jdm_itr
Jun 8, 2009 02:37 PM
918eg
Sep 4, 2008 02:05 PM
sloem2
Honda Civic (2001 - 2005)
Nov 13, 2007 11:40 AM
SE7EN3S
14
Aug 23, 2004 01:02 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
