Who makes the largest sway bars??
I am in the market for a new sway bar for my civic. The largest rear diameter I can find is a 24mm (Cusco Bar) followed by 22mm (Comtech & Progress).
Anyone know of a larger than 24mm rear sway bar??
BTW: Did search prior to posting. Didn't see much.
Thanks guys
Thanks guys
Re: Who makes the largest sway bars?? (SE7EN3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S »</TD></TR><TR><TD CLASS="quote">I am in the market for a new sway bar for my civic. The largest rear diameter I can find is a 24mm (Cusco Bar) followed by 22mm (Comtech & Progress).
Thanks guys</TD></TR></TABLE>
what kind of car do you have?
https://honda-tech.com/zerothread?id=785497
Re: Who makes the largest sway bars?? (Jon V)
I have a 99 Civic EX, but with rear Si suspension conversion (including rear disc brakes, lower control arms etc.)
Re: Who makes the largest sway bars?? (hayabusa160)
I don't necessarily want the largest I can find, I'm really just doing my homework and comparing differant companies. As of now, I am most inpressed with the Comptech with lower tie combo(22mm). Is anyone running this set up?? If so, what do you think?
Do you know who makes the 42mm?
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Have you taken into consideration what you can do to your subframe?</TD></TR></TABLE>
thats why you need this http://www.a-spec-racing.com/product2.php read this whole thread about the above ASR reinforcement kit here https://honda-tech.com/zero...age=1
this is engineered to be MUCH stronger then the beaks kit
ASR has a hollow 32" bar too
Re: (SE7EN3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S »</TD></TR><TR><TD CLASS="quote">Do you mean like traction control bars and such??</TD></TR></TABLE>
no he is taking about subframe tearout.... GO READ THE WHOLE THREAD that Jon V & I BOTH posted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S »</TD></TR><TR><TD CLASS="quote">Do you know who makes the 42mm?</TD></TR></TABLE>
I don't think you need anything that big. I have the ASR 32mm hollow sway bar & reinforcement plate setup on my hatch, and i am lovin it
read that thread about the A spec Racing stuff, then come back if you still ahve some questions.
Too stiff of swaybars will cause your inside tires to lift off the ground in a corner. Bigger is not better.
I like the Progress swaybars.
Do you have a need for a car that is oriented toward oversteer at the limit?
Do you autocross?
Are you running a stiff shock and spring combo???
Do you autocross?
I have the comptech sway/tie combo. Best thing I ever bought for the car. I think I had more satisfaction from that than when I put in my super charger.
p1driftfiend
14
02-23-2004 12:18 PM
bw54867
10-14-2002 06:51 PM
