wiring knock sensor
Old Mar 21, 2007 | 06:27 AM
95hatchcivic's Avatar
Default wiring knock sensor
hey
does a d16z6 have knock sensor? if so..where is it located? how do i pin it to the ecu? i just pinned in vtec with a p28 ecu in this motor and im still reading CEL i am thinking its knock sensor.
Old Mar 21, 2007 | 06:40 AM
usdmEHboy's Avatar
Default Re: wiring knock sensor (95hatchcivic)
no knock sensor on the d16z6
Old Mar 21, 2007 | 07:10 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmEHboy &raquo;</TD></TR><TR><TD CLASS="quote">no knock sensor on the d16z6 </TD></TR></TABLE>
True story.
Old Mar 21, 2007 | 07:28 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">hey
does a d16z6 have knock sensor? if so..where is it located? how do i pin it to the ecu? i just pinned in vtec with a p28 ecu in this motor and im still reading CEL i am thinking its knock sensor.</TD></TR></TABLE>
P28 ECU doesn't have knock sensor circuitry either, so your CEL isn't coming from this...
Old Mar 21, 2007 | 10:07 AM
Relic1's Avatar
Don't guess, check which CEL it is...
Old Mar 21, 2007 | 03:38 PM
WEIRD! OK..
I did the CEL check thing and it is saying code # 19 automatic transmission lockup control valve I dont have an automatic, Although my ecu (p28) IS from one. Does this matter? why am i getting this code on my D16z6
Old Mar 21, 2007 | 03:52 PM
EE_Chris's Avatar
Default Re: (95hatchcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">Does this matter?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">why am i getting this code on my D16z6</TD></TR></TABLE>
Because...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">my ecu (p28) IS from one [but] I dont have an automatic.</TD></TR></TABLE>
Old Mar 21, 2007 | 03:55 PM
so will my p08 work? its from a stick.. 1991...
Old Mar 21, 2007 | 04:00 PM
Default Re: (EE_Chris)
will my P08 work? its from a 1991 d15b vtec (stick)
Old Mar 21, 2007 | 04:04 PM
94eg!'s Avatar
#1 Super Guy
Loved
I don't think so since the 91 ECU isn't obd-1 like the car...
Old Mar 21, 2007 | 04:08 PM
it still works tho. like te car starts up and drives... i had it in a few days ago b4 i plugged in vtec
Old Mar 21, 2007 | 04:18 PM
fmrprojects's Avatar
you need a manual p28 ecu
Old Mar 21, 2007 | 04:19 PM
The P08 will not work then??
Old Mar 21, 2007 | 04:47 PM
do i still have vtec with the p28..asking because i cant tell if its working..motor pulls very hard without it
Old Mar 21, 2007 | 06:36 PM
^^ttt.please help
Old Mar 22, 2007 | 06:24 AM
^^ uuup. common just a simple answer
Old Mar 22, 2007 | 08:05 AM
Relic1's Avatar
convert the auto P28 to manual... http://www.pgmfi.org/twiki/bin...anual
the P08 will work, JDM 1991 is OBD1 and tends to be the same as USDM 92. Not always though...
Even though you an use the P08, the P28 would be suggested due to slightly different internal settings to the ECU.
Old Mar 22, 2007 | 09:30 AM
how do you use this jumper wire? what is a jumper? i'd like to convert my ecu but this looks difficult..i need some more simple step by steps on the matter..if someone would give me the abc's i would appreciate it
Old Mar 22, 2007 | 09:36 AM
Relic1's Avatar
IF you can solder, and only if you can solder well should you try to tackle this project. If you mess something up you will be using that P08.
If you know someone that can work with this sort of thing tell them to remove RP17 and jumper RP18.
it's a two minute job for someone that knows how to solder well.
Old Mar 22, 2007 | 09:39 AM
Default Re: (Relic1)
ok i think i can do it myself without a problem, just when u say jumper..do u mean one of those little connectors? do i have to go to radio shack to get one? whats the exact name of it
Old Mar 22, 2007 | 11:51 AM
^^^^^^ top
Old Mar 22, 2007 | 12:23 PM
Relic1's Avatar
from WIKIpedia - a jumper is a short length of conductor used to close a break in or bypass part of an electrical circuit.
best way to do it....
remove RP17 and RP18
solder in one leg from another resistor into RP18 location.
Old Mar 22, 2007 | 12:30 PM
hmm. would you send a pic of how to do this? im not sure what to do exactly..better visual learner
bokamper17
May 20, 2009 08:29 PM
1gEF-8
Jun 4, 2005 11:58 AM
p3lon21
Mar 18, 2005 03:18 PM
hatchback_al
Nov 21, 2004 04:37 PM
bullock
Aug 3, 2003 03:07 PM
