loss of power around 4000rpm, bad ignitor?
Old Mar 20, 2007 | 08:29 PM
boosted96coupe's Avatar
Default loss of power around 4000rpm, bad ignitor?
I have a 96 civic with a b18b and running a pr4. When im driving it, it feels like the motor boggs down a little bit usually around 4000 rpm. I replaced the fpr, fuel rail, injectors, plugs, wires, cap and rotor. Im thinking it might be the ignitor. It also misses and sputters bad until the engine reaches operating temp. Any ideas?
Old Mar 21, 2007 | 07:15 AM
Default Re: loss of power around 4000rpm, bad ignitor? (boosted96coupe)
bump
Old Mar 21, 2007 | 07:36 AM
bump!
Old Mar 21, 2007 | 07:38 AM
jus_spooln_wicha's Avatar
ok... its your ecu for shur.. i just had the same issue with my eg .. i have a gsr... its your ecu.. buy a new ecu and it will solve all your problems
Old Mar 21, 2007 | 09:33 AM
Stins~b20VTEC's Avatar
Default Re: loss of power around 4000rpm, bad ignitor? (papa_jon)
hey try the fuel filter and fuel pump.... did you replace those parts with bigger and better parts or with stock? you may need a bigger fuel pump... good luck
Old Mar 21, 2007 | 11:41 AM
Default Re: loss of power around 4000rpm, bad ignitor? (Stins~b20VTEC)
It still has the original fuel pump and filter with 180,000 miles on them.
crnimacak
Apr 21, 2006 10:11 PM
efcivic757
Sep 3, 2005 09:35 AM
acurateggy93
Jul 25, 2005 04:59 AM
TegBen
Nov 19, 2003 03:47 PM
KaiITR
Jun 17, 2003 07:51 AM
