Engine stutters
Old Sep 2, 2005 | 03:38 AM
efcivic757's Avatar
Default Engine stutters
After my car warms up and I'm under 3k rpms and give it anymore the 1/4 throttle the engine stutters and hesitates really bad. Once it get up to 3K though, it runs great. At first, I thought it was because I was running a chipped ecu and was getting too much fuel and just drownding the motor out, but I went back to a stock ecu and it is still doing it. Does it sound like a timing issue, bad tps, fuel pump, Dizzy, cap and rotor? No clue where to look right now. My head hurts from thinking what it could be. Just thought I ask before I start ripping everything apart. And it is on a 97 JDM B20B.
Old Sep 2, 2005 | 04:03 AM
97tegGS's Avatar
Have you replaced your fuel filter.It may be clogged. So when you get above 3k it has enough pressure to push through what you need.
JUst a thought
Old Sep 2, 2005 | 04:31 AM
vtec18l's Avatar
Default Re: (97tegGS)
check your fuel filter and your injectors
Old Sep 2, 2005 | 06:12 AM
efcivic757's Avatar
Fuel filter was already changed. Thought about that. and Thinking it may be the injectors.
Old Sep 2, 2005 | 09:11 AM
efcivic757's Avatar
Rotor was broke. Change cap and rotor, but still doing it.
Old Sep 2, 2005 | 11:35 AM
efcivic757's Avatar
New plugs, cap and rotor, Timing is dead on. The sputting is gone, but now breaking up throughout the rpms.
Old Sep 3, 2005 | 09:35 AM
vue_moua's Avatar
Default Re: (efcivic757)
o2 sensor, im guessing.
dobbs1027
Dec 28, 2004 03:17 PM
bgoetz
Oct 13, 2004 04:47 PM
KaiITR
Jun 17, 2003 07:51 AM
lbjoe
May 22, 2003 04:41 PM
Lonny
Apr 13, 2003 01:12 PM
