loss of power around 4000rpm, bad ignitor?
I have a 96 civic with a b18b and running a pr4. When im driving it, it feels like the motor boggs down a little bit usually around 4000 rpm. I replaced the fpr, fuel rail, injectors, plugs, wires, cap and rotor. Im thinking it might be the ignitor. It also misses and sputters bad until the engine reaches operating temp. Any ideas?
Re: loss of power around 4000rpm, bad ignitor? (boosted96coupe)
ok... its your ecu for shur.. i just had the same issue with my eg .. i have a gsr... its your ecu.. buy a new ecu and it will solve all your problems
Re: loss of power around 4000rpm, bad ignitor? (papa_jon)
hey try the fuel filter and fuel pump.... did you replace those parts with bigger and better parts or with stock? you may need a bigger fuel pump... good luck
crnimacak
04-21-2006 10:11 PM
acurateggy93
07-25-2005 04:59 AM
