need help quick!!!!!!!!!!
Old Mar 20, 2007 | 06:29 PM
jdmjunkie24's Avatar
Default need help quick!!!!!!!!!! obd2 into obd1
have a 92 si hatch, blew the motor, so I got a 98 d16y7 basically free, swapped in the motor, changed the alternator and the distributor(using the harness off the old motor) tried to use the old injectors, but they wouldnt fit, but my biggest problem is the car runs, but it wont rev above 1800 rpms.......
Old Mar 20, 2007 | 07:13 PM
O RLY's Avatar
Default Re: need help quick!!!!!!!!!! obd2 into obd1 (jdmjunkie24)
Sounds like an ECU issue. What are you running?
Old Mar 20, 2007 | 07:30 PM
Default Re: need help quick!!!!!!!!!! obd2 into obd1 (O RLY)
stock si ecu
Old Mar 20, 2007 | 07:33 PM
Nongan's Avatar
did you get a conversion from obd1->obd2? if not, your using obd2 stuff on obd1 ecu, which may cause it to go into limp mode......don't take that as fact till you get another opinion, but thats my guess.
Scotty Dosent Know
13
Oct 11, 2005 08:46 AM
VTECPowerdSi
Oct 16, 2004 04:20 PM
Dpatton
Oct 16, 2003 10:47 PM
allmtr
Jun 9, 2002 04:39 PM
Malachi
Apr 21, 2002 05:08 AM
