Does a corroded wire=bad conductor?
Old Mar 20, 2007 | 05:16 PM
YoungKadafi's Avatar
Default Does a corroded wire=bad conductor?
I found on one of my fuel injector harness plugs, the shielding was stripped back a bit, and the copper wire was a bit corroded. Does it still conduct however?
would putting on some liquid electrical tape fix this? same thing on my IAT, and its RIGHT at the plug, so i cant splice a new wire in. Does it affect performance to have the fuel injector wire semi corroded liek that?
Old Mar 20, 2007 | 05:24 PM
excivicboy96's Avatar
Default Re: Does a corroded wire=bad conductor? (YoungKadafi)
yup corrosion brings up the resistance
Old Mar 20, 2007 | 05:30 PM
so the only option is the replace the connector?
Is there any kinda stuff i can slap on connections to boost the conductivity of it? as well as prevent corrosion? i think i have alot of connections that are starting to crack/split.
Old Mar 20, 2007 | 07:46 PM
JimBlake's Avatar
Default Re: (YoungKadafi)
Corrosion on the surface of the wires won't really affect the conduction thru the wire. At least not until the corrosion is so bad that most of the wire itself is GONE.
But that same corrosion can get in-between the wire itself and the connector pin that's crimped onto the wire. THAT will be a problem. So you have to evaluate where the visible corrosion is located and whether you can guess about corrosion at the crimp connection.
No madjic fix for this, unless you can work some flux in there & solder it together.
Old Mar 21, 2007 | 07:29 AM
yea ill just have to replace the connector.
However is there any kinda of epoxy/grease that will up the conductivity of the contact? like conductive grease? does this actually work? I was thinking about putting some on my grounding points/soldered/crimped contacts.
Old Mar 21, 2007 | 08:12 AM
JimBlake's Avatar
"Conductive grease" isn't really. It's grease with something like copper filings mixed in. The grease itself isn't conductive.
That's OK when you're assembling the crimped joint in the first place. Or between bolted connections - when you're assembling them in the first place.
After replacing the connector, apply some grease or something to prevent FUTURE corrosion.
williamcollins
Jul 8, 2017 01:24 PM
Spicoli v 3.0
Audio / Security / Video
23
May 3, 2007 05:25 PM
D16Z6racing
Mar 21, 2007 05:56 AM
streetstylenperformance
Feb 26, 2004 03:28 PM
