supercharger or turbo
Old Mar 20, 2007 | 04:47 PM
sasinorm01's Avatar
Default supercharger or turbo
i have a ef sedan with a z6 .... i was thinking of going with a turbo setup...but i was wondering if a supercharger sytem would be just as good... im looking for around 225-250 hp for a daily driver..what dou you guys recommend
Old Mar 20, 2007 | 04:51 PM
gator88's Avatar
Default Re: supercharger or turbo (sasinorm01)
where do you want your power to be and what kinda budget. I believe it would be cheaper to turbo 225whp than SC225whp. if ur a torque lover SC all the way. The forced induction forum would know best though, along with streetwerks and tallkyle and the "experts"
Old Mar 20, 2007 | 05:05 PM
bluelsvtecda9's Avatar
turbo it
Old Mar 20, 2007 | 05:08 PM
Autoworks's Avatar
Default Re: supercharger or turbo (bluelsvtecda9)
turbo.
Old Mar 20, 2007 | 05:23 PM
sasinorm01's Avatar
should i change the internals with a turbo or a supercharger
Old Mar 20, 2007 | 05:25 PM
EF001282's Avatar
For 225-250? turbo
Old Mar 21, 2007 | 11:14 AM
sasinorm01's Avatar
would a sc cost more or less the a turbo system
Old Mar 21, 2007 | 11:20 AM
CRX Toad's Avatar
Default Re: (sasinorm01)
First, off what do you want to do with the car?
Second, where do you want the power to be? (instant or higher up in the RPM range)
Third, are you going to buy a turbo kit or make your own?
Superchargers typically don't make as much power, but they make it fairly instant which can make for some fun power down low.
Turbos typically have higher power numbers but you have to wait for it to spool so your basically looking for the motor to pull you up to a certain RPM where the turbo spools up.
I personally think either would be a ball. A might lean towards a SC knowing that I can't make as much power as a turbo but that my power is right there when I want it.
Old Mar 21, 2007 | 01:16 PM
sasinorm01's Avatar
i want a daily driver with some power, not a lot, i would like to have the power right from the start since its not going down a track but from stop light to stop light...and from reading the write ups on this forum ill probably make my own kit if i was going to go that way
Old Mar 21, 2007 | 01:21 PM
johnickys ek's Avatar
supercharge all day
biada1
Dec 7, 2006 04:08 PM
dk-fabrications
Oct 17, 2004 12:04 AM
CivicSmkYa21
May 19, 2004 10:06 AM
ramz7887
Aug 14, 2003 06:18 PM
1BadLude6986
Oct 12, 2002 02:47 PM
