Fuel air metering code p1259 ????
Old Mar 20, 2007 | 03:29 PM
1clean_ Ej's Avatar
Default Fuel air metering code p1259 ????
Whats this code mean Fuel air metering code p1259? What could cause this code? and what could i do to fix it? I just out a d16y8 in my 97 dx and I used a 96-98 ex harness and 96-98 ex ecu I dont think it was throwing any codes before we put it in my car so why would it now? all the sensors are good and everything is hooked up. Iev tryed everything and still the same code and still the same ol runnin like **** motor .........I need help if anyone thinks they know what it is im up for hearing it!
Thanks, 1clean_ Ej
Old Mar 20, 2007 | 04:12 PM
1clean_ Ej's Avatar
Default Re: Fuel air metering code p1259 ???? (1clean_ Ej)
anyone?
Old Mar 20, 2007 | 07:35 PM
JimBlake's Avatar
My list says P1259 is a VTEC system malfunction. Don't know whether it's the VTEC oil pressure switch or the VTEC solenoid.
Old Mar 20, 2007 | 08:07 PM
1clean_ Ej's Avatar
Default Re: Fuel air metering code p1259 ???? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">My list says P1259 is a VTEC system malfunction. Don't know whether it's the VTEC oil pressure switch or the VTEC solenoid.
Yea thats what my hanes manual says it is......but it came up as fuel air metering with a scan tool. So dose this mean its a vtec system malfunction or is it something else???
Old Mar 21, 2007 | 04:40 AM
JimBlake's Avatar
Any OBD-2 error code above P0999 means different things for different car companies. P1259 probably means a metering error for Ford or Chevy...
Sometimes the scan tool has a setting for what kind of car it's reading. The actual code number is what you should believe, but the text description changes.
Old Mar 21, 2007 | 05:39 AM
EE_Chris's Avatar
Like Jim said, P1xxx codes are manufacturer specific and P1259 for Honda is listed as a VTEC system malfunction. That's what I'd go with.
Old Mar 21, 2007 | 08:06 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Don't know whether it's the VTEC oil pressure switch or the VTEC solenoid.
</TD></TR></TABLE>I think it's the VTEC oil pressure switch. Check that.
ghettoSi
Jan 11, 2008 11:39 PM
Playa_FL
Nov 14, 2007 10:35 AM
MugenHonda
Jan 5, 2006 06:52 PM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
2trix
Apr 2, 2004 08:15 PM
