compresion test
Old Mar 20, 2007 | 12:56 PM
proda9driver's Avatar
Default compresion test
Hey guys i want you guys to see my compresion test that i did #1 piston is 120 #2 piston is 160 #3 piston is 165 #4 piston is 160 i just wanted yall suggestion
Old Mar 20, 2007 | 01:14 PM
simon98h22's Avatar
Default Re: compresion test (proda9driver)
What year and trim is your car?
Ideally? You want a good grouping of numbers.
IE 165-160-163-165
If I had your numbers, I'd
A) Redo the test a few times to make sure that's what I had
B)Try to determine why #1 is losing so much pressure (A leakdown test would probably help you here)
Search on here, you'll find some info.
https://honda-tech.com/zerothread?id=1863822
Modified by simon98h22 at 10:26 PM 3/20/2007
Old Mar 20, 2007 | 03:09 PM
sauceja's Avatar
Default Re: compresion test (simon98h22)
for a ls motor those might be good.
If it is gsr then you will want 185 or a little higher.
vtec_bangeR
Jan 12, 2008 07:54 PM
JunY
Welding / Fabrication
May 20, 2005 10:27 PM
DxTrix
Aug 15, 2003 04:58 PM
Propulsion
Jun 5, 2002 11:48 PM
