2000 front end conversion on a 96 dx
Old Mar 20, 2007 | 11:06 AM
x8_andrew_8x's Avatar
Default 2000 front end conversion on a 96 dx
i have a 96 dx and someone keyed the expletive out of my car and it needs to be repainted but before i paint it i wanna put a 2000 front end on it and then get it painted but i have been asking some people and they r telling me i need to cut off my radiator support and put the one from the 2000 on it and some other people are telling me i dont have to so im not too sure i know alot about my car but i have never done the conversion before so im basicly looking for a 2000 front end to buy off of someone or if someone knows a website to get one and i need to know if i really need to change the radiator support or if i can rig something up to fit the front end on it!!
Old Mar 20, 2007 | 11:09 AM
alacard's Avatar
The answer is no, you don't need the radiator support. All you have to do is cut a little slit on each side of the bumper near the grill so that it will slide onto the 96-98 radiator support. its not a big deal and its not even visible unless you pop the hood and are really looking for it. If you want to go through the trouble of locating a 99-00 rad support, and have it welded, then go ahead...but its not necessary.
Old Mar 20, 2007 | 11:11 AM
JLEK's Avatar
Default Re: 2000 front end conversion on a 96 dx (x8_andrew_8x)
the proper way is to modify the radiator support by cutting off two small pieces then you can bolt on using all the mounting points. way better imo.
http://www.jdmuniverse.com/for...rsion
Old Mar 20, 2007 | 11:34 AM
alacard's Avatar
Default Re: 2000 front end conversion on a 96 dx (emperor9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emperor9 &raquo;</TD></TR><TR><TD CLASS="quote">the proper way is to modify the radiator support by cutting off two small pieces then you can bolt on using all the mounting points. way better imo.
http://www.jdmuniverse.com/for...rsion</TD></TR></TABLE>
hmm, wasnt aware of this method when i did mine. sounds like the better alternative, but i cant see the link since im not a member.
Old Mar 20, 2007 | 11:58 AM
ITS_Dunn's Avatar
fenders bumper headlights grille hood and youre good to go
reyrey2006
16
Jul 29, 2008 10:19 PM
i-vtec_DO_YOOH
Jul 14, 2007 12:31 PM
george85
17
Jul 6, 2007 06:24 PM
JDean6pac
12
Mar 23, 2007 01:44 PM
Civic2Integra
Jan 22, 2007 08:54 PM
