Shifter??????
Well my shifter was working fine up until last week when i was driving home and its started acting wierd. It will go into every gear, but all the gears are alot higher. For example first is almost 2 inches higher than normal and etc... Also when i shift into any gear the shifter jerks back a little and shakes around, with each jerk of the motor and it is very noticable. I checked the shift linkage and it is tight i have no idea what it could be .. the rear mount is also fine so i am just wondering if anyone can gimme any ideas on what it could be >>? Thanks ....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Bad bushing in the linkage?</TD></TR></TABLE>
x2
x2
get under ur car and right where ur shifter is there should be a bushing with 2 bolts holding it up. should be right under the shifter. see if those are attached. that piece of rubber makes it so ur shifter flies back to the middle. if thats not the case check the bushing in the linkage. that will be on the tranny end.
