what rear bracket do i need?....
Old Mar 20, 2007 | 08:52 AM
92integra-R's Avatar
Default what rear bracket do i need?....
im putting a b18a1 with 98 LS tranny in a 95 civic. i got the drivers side mount off a B1 (aluminum one). i got the a/c bracket from a (b16) del sol. then i planned on using the two tranny mounts from the old D16 tranny.? will those work? and then finally the back bracket. i tried a 92 integra one, it didnt seem like it was the right one. anyone know what one i need? part #? oh yeah, i got the shift linkage outta a 92 integra, will it work??
Old Mar 20, 2007 | 08:54 AM
ITS_Dunn's Avatar
Default Re: what rear bracket do i need?.... (92integra-R)
you can use the d series mount but not bracket
rear bracket has to be bseries from 94 - 01 teg or 99 - 00
Old Mar 20, 2007 | 09:34 AM
Default Re: what rear bracket do i need?.... (Dunn@ITS)
ok, i now know all the brackets i need, what about a 92 half-shaft? and 92 axles? or do i need the 94 and up axles?
Old Mar 20, 2007 | 11:29 AM
BlueIntegraBoy's Avatar
If you use the 92 Integra half shaft, you need 90-93 Integra axles. If you use 94-01 Integra half shaft, use 94-01 Integra axles.
Old Mar 20, 2007 | 02:21 PM
Default Re: what rear bracket do i need?.... (BlueIntegraBoy)
i went got that rear bracket i needed off a 98 LS automatic. the bracket doesnt work, and i also snagged the starter. it also dont bolt to the tranny. i paid the dude at the junkyard 20 bucks to pull these parts. good thing.
Old Mar 20, 2007 | 09:00 PM
hatchi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra-R &raquo;</TD></TR><TR><TD CLASS="quote">i went got that rear bracket i needed off a 98 LS automatic. the bracket doesnt work, and i also snagged the starter. it also dont bolt to the tranny. i paid the dude at the junkyard 20 bucks to pull these parts. good thing.</TD></TR></TABLE>
is your car auto or manual?? you will need manual if your car is a manual.
Old Mar 20, 2007 | 09:06 PM
pdiggitydogg's Avatar
both starter and bracket need to be for manual
0ne-Cam
May 6, 2009 09:32 AM
racingcrx
Aug 15, 2006 07:47 AM
BLUE EH3
Dec 9, 2003 09:08 AM
See Are X
Jan 23, 2003 07:26 PM
Hayasa15
Apr 18, 2002 02:32 PM
