Installing A tranny
Old Mar 20, 2007 | 05:52 AM
wizeguy1's Avatar
Default Installing A tranny
00 si originally had a b16a2, now will b installing a b16a with lsd, i was wondering besdies the clutch and flywheel, is there anything important that i should worry about when putting in the tranny?. I got the shiftlinkage, along with 2 new mounts for it. Flywheel, Clutch, Tranny, mounts, linkage, then starter? thats the order it is going in.
is this more or less correct, is there anything else should b aware of?
First time installing, i will b with other mechanics i just want to kno for myself, thanks
Old Mar 20, 2007 | 06:43 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
you be golden! Make sure all the bolts are off, before you start prying the transmisson.
Old Mar 20, 2007 | 07:22 AM
3.point.2's Avatar
just remember to grease the throwout bearing. sounds like you got the rest taken care of
Old Mar 20, 2007 | 07:40 AM
JDM_Frijoles's Avatar
Default Re: Installing A tranny (wizeguy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizeguy1 &raquo;</TD></TR><TR><TD CLASS="quote">is this more or less correct, is there anything else should b aware of?
First time installing, i will b with other mechanics i just want to kno for myself, thanks</TD></TR></TABLE> DO NOT, I REPEAT DO NOT FORCE THE TRANS AGAINST THE BLOCK. Wiggle it till it slides in, you can expletive up your trans like that. I did Man, that was a costly lesson.
Modified by JDM_Frijoles at 11:16 AM 3/20/2007
Old Mar 20, 2007 | 07:49 AM
Default Re: Installing A tranny (JDM_Frijoles)
I believe, thats how one of my buddies ruined theres. A well known machanic made a terrible mistake buy tightning one of the tranny bolts, hopeing it will aligned it self to the block.
Old Mar 20, 2007 | 09:37 AM
3.point.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles &raquo;</TD></TR><TR><TD CLASS="quote"> DO NOT, I REPEAT DO NOT FORCE THE TRANS AGAINST THE BLOCK. Wiggle it till it slides in, you can expletive up your trans like that. I did Man, that was a costly lesson.
Modified by JDM_Frijoles at 11:16 AM 3/20/2007</TD></TR></TABLE>
good advice.
when ive put tannies back on i usually get two thick screw drivers and put them through bolt holes into the tranny and into the block where the bolts would go which makes it a little easier to line the tranny up. then i usually hold it in place while someone turns the flywheel slightly until the tranny slides in.
Old Mar 20, 2007 | 09:40 AM
Ricey McRicerton's Avatar
Default Re: Installing A tranny (h23eg)
Loc-tite the flywheel bolts if you plan to have them off. I had a how to on a tranny removal, but it's basically the same as an install.
Also get you a good jack to take the weight/angle off of the block, it'll help you a ton getting it back in. Just get under the car, press it up, and have somebody on top help wiggle it in.
Cln94EG1
Nov 25, 2007 05:19 PM
daroq69
14
Jul 31, 2007 02:53 PM
97RSTEG
Dec 4, 2006 07:48 PM
18gLUDE
Feb 13, 2005 09:44 PM
blacksheep
Nov 14, 2003 11:10 AM
