swhich ecu do i run?
Old Mar 20, 2007 | 05:17 AM
egboostin6's Avatar
Default which ecu do i run?
having problems with lack of power and confusion as to if vtec is engaging...i unfortunatly do not know which ecu i am running now, but which one should i be running with an LS/VTEC with a b16 obd0 head? thanks guys
Old Mar 20, 2007 | 06:58 AM
DC2 Mang's Avatar
Default Re: which ecu do i run? (egboostin6)
chipped p28 then go and get it tuned
Old Mar 20, 2007 | 07:06 AM
Boostedb20EH2's Avatar
Default Re: which ecu do i run? (DC2 Mang)
Like what DC2 Mang said get a p28 and chip it.
Old Mar 20, 2007 | 11:14 AM
egboostin6's Avatar
Default Re: which ecu do i run? (Boostedb20EH2)
but its obd0...isnt the p28 for obd1?
Old Mar 20, 2007 | 11:23 AM
1badteg's Avatar
check to see if there is a conversion harness. if there isnt then you are probably going to need to find another ecu setup.
Old Mar 20, 2007 | 11:42 AM
egboostin6's Avatar
Default Re: (1badteg)
you think if i ran a chipped pr3 would halp figure out the problems?
Old Mar 20, 2007 | 12:28 PM
doood's Avatar
been there done that
Default Re: (egboostin6)
any obd1 ecu can be chipped to run your engine. once chipped it doesnt matter which one you use.
TurbodTegra
Mar 10, 2011 12:46 PM
91_ef_hatch
May 8, 2008 01:32 PM
redefsir
16
Jun 13, 2007 11:38 AM
Youlose1305
Jul 10, 2006 09:16 AM
roc109
Nov 19, 2002 09:06 PM
