ABS system removal.
so i went through all the threads from the prelude forum and i did not see a write up for ABS system removal. jus wondering if i missed it or if there isnt one.
if there none can anyone tell me teh basics on it. the main things i need to do. i have a slight clue but i need reassurance b4 i do it.
thanx for ur help and hope this doesnt get bashed
Official how to remove ABS thread: https://honda-tech.com/zerothread?id=1347569
Just use the search button under archived threads.
On the 5th gen do you have to remove the lines to the rear also because it is 4 wheel abs. Also i am alittle unclear about where the proportioning valve is located ? Would running the prelude s brake booster help or hurt braking ? And lastly can you leave the abs axles ??
cutting the lines makes up for a lot of time. also all you need to do to remove the brake booster is remove the IAT sensor. it comes out easily if you turn it the right direction. a hard part is finding the bolts that hold the abs unit on without being able to see them. any questions, PM me.
